Hello
Can anyone tell me how i go about making a Mp4 dvd with menus and name of software to use?
Many thanks...
There's no such thing as "mp4 dvd". Either you have a dvd iso (or files and folders on drive) utilizing vobs which contain mpeg2 video, or you have an mp4 file(s) that is a rip+conversion from the above, and mp4 does not support menus (neither does mkv).
Scott -
Same difference. Both dvd and bluray have no menu equivalent in mp4, mkv. Closest one could get would be a sidecar html file w links to clips..if the player accepts it. Asx/wvx metafiles can do playlist but even they don't do menus.
Menus never got finalized for mp4 or mkv. Mov had a form of this, but the creation was complex pain, now uses very defunct software. Adobe/Macromedia director & flash had a similar capability, but that is gone now also.
ScottLast edited by Cornucopia; 10th Apr 2022 at 15:07.
Thanks for replies.
Its been many years since i've done any Video Conversion's i should have realised. If i remember, couldn't you make Dvix discs with menus at one time? However i may be wrong.
Thanks -
You are thinking of Divx Ultra. You could try that, but you would have to use 20 year old proprietary technology to create the divx file (a glorified AVI file), into that proprietary format, that was never as common/popular as even dvd or bd. And you would have to use a player that was explicitly certified to support divx ultra menus, which means probably either certain old hardware players, and cyberlink powerdvd, and maybe that's it? A very Rube Goldberg sort of solution and one which loses a good deal of quality in the process. That alone would be a deal breaker for me.
Scott -
Hi Scott
Oh well no worries. Thanks for your time and information given, much appropriated. ATB -
Since it is established that no straight-to-disk program exists for native mp4 and re-encoding is the only option beit something simple like avstodvd which will give you a menu.
Another more evolved option would be MultiAVCHD which will take your mp4 files, create a file system on a regular dvd but for playback in a blu-ray player (no support for a dvd player). This will also give you a menu.
Merge .srt & .mp4 without encoding video & audio?
By alexeliasson in forum SubtitleReplies: 9Last Post: 11th Jan 2021, 10:42 -
Mux video w/subtitles into MP4 from Context Menu or Shortcut
By Chris Dukes in forum Video ConversionReplies: 1Last Post: 25th Nov 2020, 22:46 -
whats the best program for edit MENU, VIDEO & AUDIO DVD?
By enable in forum Authoring (DVD)Replies: 8Last Post: 26th Oct 2018, 13:43 -
m4s to mp4 & m4a?
By ghostrewel in forum Video Streaming DownloadingReplies: 8Last Post: 13th Jun 2018, 02:31 -
prevailing best method for converting .mp4/avc&aac into .mkv/avc&mp3 ?
By hydra3333 in forum Video ConversionReplies: 6Last Post: 31st Dec 2017, 19:24
