Hello,
I got a DVD on my Hard Drive which I want to rip to individual VOBs based on Chapters, but I can't work out how...
I tried using River Past DVD Quickrip, but you need to pay in order for it to properly work and the companys site is down.
Are there any alternatives?
The DVD has 2 different Audiostreams (LPCM, and 5.1 DTS-HD) which I both want to include into the VOB files.
Thanks for any help!
Results 1 to 10 of 10
Read directions further, you should be able to choose chapters, streams. Have done this many times, though most times I demuxed to elements. It's been awhile (5 years?) since I last did this, but the documentation is out there.
Scott -
But I can't get my DVD loaded up in DVD Decrypter, how do I do this?
I got ti to load now. I created an iso image from my DVD folder with Anyburn and mounted that into Windows Explorer. That way DVD Decrypter recognized it as a drive/disc.
Only problem now, DVD Decrypter creates VOB with a length of ~15 Min. which are the same as in the DVD folder. It didn't split the Disc by chapters... -
You don't have to do that. With it already decrypted to the hard drive, you just mount it using DAEMON Tools Lite or Virtual CloneDrive or some such. Then you can use DVDDecrypter to break it into chapters. I don't have DVD Decrypter on this computer, but look around in Mode or Tools and you'll find it.
Or, with the DVD on the hard drive, open PGCDemux, hit the dropdown box and extract the chapters. But that's one-by-one.
Edit Later: Either with the DVD in the player or with it already decrypted to the hard drive and mounted, perhaps in Virtual Clone Drive, open DVD Decrypter and go Tools->Settings->File Mode->File Splitting->By Cell ID.Last edited by manono; 11th Apr 2022 at 02:14.
I didn't know about that setting. I only read that you need to go to "Mode ---> Ifo" but that didn't work (porb. because I neede to change the setting you mentioned.
Anyways, "Streamripper" works just fine and I didn't needed to mount anything...
But I didn't know you could mount a folder directly. Thanks for the Tip!
RIP Thunderbirds DVDs to MKV using Handbrake: 2 VOBs to one MKV?
By JDMils in forum DVD RippingReplies: 2Last Post: 7th Jun 2021, 20:18 -
DVD Playing more video that what is in the VOBs?
By crbd98 in forum Newbie / General discussionsReplies: 9Last Post: 20th Feb 2021, 11:55 -
Individual digits in MORSE in Videopad
By Camerart in forum EditingReplies: 0Last Post: 10th Dec 2020, 10:28 -
Ripping DVD TV Series Discks to individual MP4 files
By Fozzie_Bear in forum Authoring (DVD)Replies: 9Last Post: 24th Feb 2020, 23:01 -
Avisynth - just use the VOBs or convert the VOBs to MPG first?
By pooksahib in forum Video ConversionReplies: 5Last Post: 28th May 2019, 01:51
