https://forum.videohelp.com/threads/405370-Trying-to-capture-DVI-out-from-a-1280x1024p...a-Magewell-USB
please reply in the Newb thread above - I am cross-posting in the Capture forum, didn't know there was one....
First post newbie here....
I have a circa 2008 thermal camera manufactured by L3 (actually, thermal with Image Intensifier, digitally fused). The goal is to be able to record the digital video, ideally using portable battery-powered hardware.
The thermal camera has a wonky proprietary port for video out, and can allegedly output "DVI" and "NTSC" video formats. It came with a cord that converts to female DVI-I port, but I don't think there is any analog on it.
If I hook the thermal camera up to a DVI computer monitor (such as Dell S2309W) with a DVI-D single link cable, it recognizes the video as 1280x1024p60.
If I hook the thermal camera up to an HDMI computer monitor (Samsung) via a bidirectional DVI to HDMI cable or dongle, the monitor recognizes the video as 1280x1024p60 with 64.0kHz horizontal sync rate.
I have an Atomos Ninja V that does not recognize the HDMI stream. I recently acquired a Magewell USB Capture HDMI 4K Plus. Although it lists 1280x1024 as an accepted HDMI format, it is not able to identify the video output or lock on it.
There is a place to edit EDID values, front porch, etc. as well as the precise frame rate. I have tried most of the common ones for 1280x1024p60 VESA.
Any idea how to get more diagnostic info off the DVI video, and/or figure out a way to grab the video?
Closed Thread
Trying to capture DVI out from a 1280x1024p60 thermal camera - Magewell USB
By Rookie_Mistake in forum Newbie / General discussionsReplies: 17Last Post: 13th Apr 2022, 12:11 -
How do I connect video to a thermal 4000m pan/tilt
By SpikeX77 in forum Capturing and VCRReplies: 0Last Post: 24th Jul 2020, 18:13 -
USB2 HDMI Video Capture - Sony HD Video Cam to PC transfer
By pchan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 27th Feb 2019, 22:16 -
the capture card vendor's S-VIDEO adapter DVI HDMI problem
By 280634157 in forum Capturing and VCRReplies: 2Last Post: 12th May 2018, 19:53 -
Posting Video, Pictures with Music to Video
By bpatters69 in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2018, 04:24
