OK I need a little help... I am trying to burn a VCD with a CUE/BIN file. I am using Fireburner v1.06 to burn. When I try and watch the vcd in my DVD player it is choppy. The audio is very choppy and when this happens you can see the video is too. I tried slowing down the cd-rw and this doesn't seem to help. Did I get a bad cue/bin file? Is there a way to check before I burn it? What am I doing worng here?
Thanks in advance
hrm...1st...make sure you dvd player likes the particular brand of cd-r/cd-rw
http://www.vcdhelp.com/dvdplayers.php
burn no faster than 4x is u wanna make sure it can play in your dvd player
also, which settings are u using to burn the bin/cue files? for recording method, choose "session at once", and only leave "eject CD" and "close session" checked
btw, if you haven't registered your copy, you can PM me and i can give you the reg codes
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
AIFF files - burning quick audio CDs
By submerge in forum ffmpegX general discussionReplies: 4Last Post: 19th May 2008, 13:40 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 20:10 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21
