I'm interested in doing direct stream copy of video (x264 and HEVC) with multiple audio streams, and Avidemux has always been a quick, easy tool for this purpose.
However, I'm concerned about Avidemux not interpreting the colorspace correctly. While the latest release uses DXVA2 as the video decoder, previous releases tended to turn the colorspace to RGB, loosing information.
Just how safe is using DXVA? Can it correct retain the original video colorspace?
Am I missing something? Why does Avidemux's colorspace interpretation matter if you're focused on doing Direct Stream Copy?
If it inverted the colors or showed the video as black & white, that's still just the program's own display. The compressed streams are going to be copied bit-for-bit, unmolested, either way.My YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
Issues With Colorspace Conversions in VHS Captures
By balderdashian in forum Video ConversionReplies: 0Last Post: 6th Feb 2021, 05:34 -
Colorspace Conversions - YUY2 and YV12
By Christina in forum RestorationReplies: 4Last Post: 5th Oct 2020, 19:46 -
Colorspace conversion
By Sharc in forum Video ConversionReplies: 8Last Post: 1st May 2020, 10:39 -
ffmpeg yuv colorspace is BT.601 or BT.709?
By colibri in forum Newbie / General discussionsReplies: 13Last Post: 22nd Dec 2019, 02:00 -
Can you edit colorspace flag in mkv (x264)?
By nick1977 in forum Video ConversionReplies: 2Last Post: 29th Apr 2017, 19:05
