ffmpeg version 4.2.4-1ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers
My goal is to create a single 320x160 thumbnail from near the beginning of the mp4
I create an mp4 from a webm as such: ffmpeg -i video.webm -fflags +genpts -r 25 input.mp4
The resulting mp4 plays fine in Windows Media player.
Now googling, I found this command: ffmpeg -ss 5 -i input.mp4 -vframes 1 output.png
But I get this error:
root@broadcast:/var/www/html/uploads# ffmpeg -ss 5 -i input.mp4 -vframes 1 output.png
built with gcc 9 (Ubuntu 9.3.0-10ubuntu2)
configuration: --prefix=/usr --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'input.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf58.29.100
Duration: 00:00:01.02, start: 0.000000, bitrate: 841 kb/s
Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x960 [SAR 1:1 DAR 4:3], 813 kb/s, 25 fps, 25 tbr, 12800 tbn, 50 tbc (default)
Metadata:
handler_name : VideoHandler
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 126 kb/s (default)
Metadata:
handler_name : SoundHandler
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> png (native))
Press [q] to stop, [?] for help
Output #0, image2, to 'output.png':
Metadata:
major_brand : isom
minor_version : 512
Stream #0:0(eng): Video: png, rgb24, 1280x960 [SAR 1:1 DAR 4:3], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc (default)
Metadata:
encoder : Lavc58.54.100 png
frame= 0 fps=0.0 q=0.0 Lsize=N/A time=00:00:00.00 bitrate=N/A speed= 0x
video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used)
Any ideas what my problem could be?
Thanks,
Ray
The MP4 duration is too short for -ss 5, you seek to the end, so get nothingDuration: 00:00:01.02, start: 0.000000
How to create video thumbnail using ffmpeg?
By iKron in forum Newbie / General discussionsReplies: 8Last Post: 28th Jul 2021, 04:01 -
How to create a BD image (.iso) from a .mp4 file
By jf314159 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jan 2021, 19:12 -
ffmpeg to create MP4
By Rayj00 in forum Video ConversionReplies: 6Last Post: 22nd May 2019, 05:50 -
Create mp4 from vobs with original grain
By episode10 in forum Off topicReplies: 1Last Post: 21st Dec 2018, 23:25 -
Why do MP4 splitters always create a file with a variable framerate?
By Hypersonic1 in forum Newbie / General discussionsReplies: 26Last Post: 3rd Nov 2018, 15:55
