I get an 'Unsupported audio format' when playing HD Audio (LPCM) inside an .mkv file. Works fine with .mt2s files. What gives? Just bought PowerDVD 21 Ultra today.
Here is an example, in full (see below). Just a standard 5.1 LPCM audio track. Plays with everything, even with PowweDVD 21, but not inside an .mkv container with an UHD stream.
Code:General Unique ID : 187114675336600084842924770818267196199 (0x8CC4F9C2A89DC20D4B1B0AA70CDEAB27) Complete name : N:\Confessions Of a Shopaholic REGRADED (UHD).mkv Format : Matroska Format version : Version 4 File size : 51.5 GiB Duration : 1 h 44 min Overall bit rate : 70.7 Mb/s Encoded date : UTC 2022-02-10 17:22:57 Writing application : mkvmerge v65.0.0 ('Too Much') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 44 min Bit rate : 63.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.321 Stream size : 46.5 GiB (90%) Writing library : x265 3.5+2-g2b25c9ba0+45:[Windows][GCC 10.2.0][64 bit] Yuuki 10bit Encoding settings : rc=crf / crf=10.0000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / no-lossless / no-cu-lossless / aq-mode=2 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / ipratio=1.40 / pbratio=1.30 / psy-rd=2.00 / psy-rdoq=0.00 / deblock=0:0 / ref=3 / limit-refs=1 / no-limit-modes / bframes=4 / b-adapt=2 / bframe-bias=0 / b-pyramid / b-intra / weightp / no-weightb / min-keyint=23 / max-keyint=250 / rc-lookahead=20 / gop-lookahead=0 / scenecut=40 / hist-scenecut=0 / radl=0 / max-cu-size=64 / min-cu-size=8 / me=1 / subme=2 / merange=57 / rdoq-level=0 / rd=3 / rdpenalty=0 / dynamic-rd=0.00 / no-rd-refine / ----- / cutree / sao / no-rect / no-amp / open-gop / wpp / no-pmode / no-pme / no-psnr / no-ssim / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / qg-size=32 / qpmax=69 / qpmin=0 / ----- / cpuid=1111039 / frame-threads=4 / numa-pools=24 / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / no-allow-non-conformance / no-repeat-headers / no-aud / no-hrd / info / hash=0 / no-temporal-layers / lookahead-slices=8 / no-splice / no-intra-refresh / no-ssim-rd / signhide / no-tskip / max-merge=3 / temporal-mvp / no-frame-dup / no-hme / no-analyze-src-pics / no-sao-non-deblock / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-splitrd-skip / zone-count=0 / no-strict-cbr / no-rc-grain / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=2 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : PCM Format settings : Little / Signed Codec ID : A_PCM/INT/LIT Duration : 1 h 44 min Bit rate mode : Constant Bit rate : 6 912 kb/s Channel(s) : 6 channels Sampling rate : 48.0 kHz Frame rate : 25.000 FPS (1920 SPF) Bit depth : 24 bits Stream size : 5.03 GiB (10%) Language : English Default : Yes Forced : No -
Could be the Bit depth (24 bits in your case).
You should check if another working PCM is 24 bits too.
mkv or m2ts are only containers, but the player fails a codec.
MKV opus audio converting
By Kracov in forum Video ConversionReplies: 24Last Post: 31st Dec 2020, 11:47 -
MKV with supported audio.
By teidybugi in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Dec 2018, 09:33 -
Change MKV Audio
By chang123 in forum Video ConversionReplies: 10Last Post: 20th Sep 2018, 19:33 -
PowerDVD does not play certain mkv files in 3D
By maeries in forum Software PlayingReplies: 4Last Post: 7th Sep 2017, 05:59 -
MKV No Audio
By wolf9368 in forum Video ConversionReplies: 1Last Post: 1st Jun 2017, 15:21
