I have a DVD, if I play the .VOB file directly in VLC, with the option "automatic" set for deinterlace. Then the picture looks great. However, if I convert that .VOB to a .mp4 with:
ffmpeg -i out.vob converted.mp4
Then when I view the mp4 in VLC, with that same "automatic" option, it looks like it's not being deinterlaced and there are awful horizontal lines everywhere. If I change the option for deinterlace in VLC to "on" then the picture looks smooth...
It appears that some how when I am converting this to mp4, some metadata is getting lost and video players think they don't need to deinterlace... I originally was converting that mp4 to m2v and burning that to DVD, and noticing on my bluray player when watching, it had all those horrible horizontal lines.
When I look at the .VOB metadata, I see:
I see it says "Bottom first" which I assume is what makes VLC know "automatic" should be deinterlacing?Code:Input #0, mpeg, from 'out.vob': Duration: 00:46:58.69, start: 3697.324300, bitrate: 6093 kb/s Stream #0:0[0x80]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, smpte170m, bottom first), 720x480 [SAR 8:9 DAR 4:3], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
When I look at the metadata for the converted mp4 file:
I don't see anything about field ordering...... Is there some flag I should be setting when converting to mp4?Code:Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'converted.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 encoder : Lavf58.76.100 Duration: 00:46:58.82, start: 0.000000, bitrate: 1710 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, smpte170m), 720x480 [SAR 8:9 DAR 4:3], 1573 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default) Metadata: handler_name : VideoHandler vendor_id : [0][0][0][0] Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default) Metadata: handler_name : SoundHandler vendor_id : [0][0][0][0]
Vob to MP4
By Cptjimkirk363 in forum DVD RippingReplies: 3Last Post: 26th Aug 2021, 09:44 -
AVCHD MTS to MP4 question on interlacing and AC3 or AAC
By TwoJ in forum Video ConversionReplies: 1Last Post: 23rd Jan 2021, 17:59 -
Converting Mp4 to Vob
By Phot01 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2018, 13:38 -
can't convert vob to mp4
By myron18 in forum Video ConversionReplies: 5Last Post: 2nd Dec 2017, 19:13 -
convert 16:9 vob to 16:9 mp4?
By xenayoo in forum Video ConversionReplies: 2Last Post: 9th May 2017, 16:07
