Hey there, newbie here.
Some time ago I bought from Amazon a video grabber "V-TOP" which I used with Windows 7 with a few to no problem. It rested there for a while but, since I have A LOT of old VHS (home made) I'd like to convert, I reinstalled it on my new (win 10) pc.
Here come the problems. I tried both with ArcSoft ShowBiz and with OBS with the same result: I can't get a good signal. In fact, the video signal keeps "jumping" back and forth a couple of frames even without a VHS inserted. I tried every PAL/SECAM/NTSC setting with no luck (Italy should be PAL B).
I have no problem using a TV.
The VCR I'm using is a Thompson DTH6100E (it's a combo DVD/VCR) and the video (and audio) signal is grabbed through AV (the grabber has also an S-Video in but the VCR doesn't).
These are my specs: Windows 10, Intel Core I7@7700K - 4.20GHz, 16Gb RAM, 450Gb SSD + 1TB @7200RPM, NVidia GTX 1080
Hope someone can help. TIA
Right out of the gate, OBS is universally frowned upon for capturing analog signals. VirtualDub 1.9.11 (?) is often recommended.
Go back to Windows 7 and get a better capture device.
After I quit torturing myself in W10 I reactivated my P360 ( 2.3GHz) Dual Core W7 lappy and never looked back.
It helps to have some TBC in the workflow, too. -
To be clear, I use the W7 laptop for capture only, I still use my W10 HP tower for the power editing.
MY capture devices are Diamond VC-500, a Hauppauge 850 and 950, 2 Tevion DVD Makers, and a Vidbox, and they all work GREAT in W7.Last edited by Barrythecrab; 4th Apr 2022 at 04:54.
Panasonic S-VHS NV-FS200 no signal video from scart
By Nicola71 in forum RestorationReplies: 15Last Post: 5th May 2021, 18:09 -
no signal vhs to computer
By ellagella in forum Newbie / General discussionsReplies: 3Last Post: 4th Sep 2020, 22:15 -
VHS Player goes to no signal ONLY when connected to RCA to HDMI adapter
By spyjoshx in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2020, 16:51 -
EyeTV Hybrid VHS capture has fuzzy signal
By crissrudd4554 in forum Capturing and VCRReplies: 59Last Post: 23rd Mar 2018, 16:27 -
Signal weak - any signal increasing strength device?
By MIRKOSOFT in forum Capturing and VCRReplies: 17Last Post: 5th Apr 2017, 18:14
