A lot of hacks to make region free and such is built on making a number sent on each numberic key and similar.
One For All is often mentioned, but don't find models referred to and reading every user manual is hard.
Another I found is Nevis that is programable from computer software, but not clear to which degree.
Had a Logitech Harmony 600 long ago, but don't remember if any numeric button could be programmed so any sequence of numbers could be sent to a unit. But shortly buttons started to stick and create problems, so quality not that great. But thought idea was great to use software on pc to configure.
About OneForAll - how much diffference is there between 12xx, 36xx or 7xxx models etc?
- all can have a sequence of 3-5 digitls on each numeric key?
Seems that very few are that flexible to create a unique sequence to send and built to enter a number of a device basically to have a particular device controlled. I guess a device or brand need to be supported since probably different chips and such.
I am just after send unique unlock sequence for region all at this point and use original remote for unit otherwise.
I'm on region 2, and want to play some region 1 dvds that I have.
Thanks for any suggestions or input on what remotes are most flexible....
I have a Philips DVP 2880 and haul up that one, since good instructions here on videohelp how to set region.
Results 1 to 1 of 1
4K authoring with FULLY CUSTOM menus - Is it possible?
By Troc in forum Authoring (Blu-ray)Replies: 25Last Post: 3rd May 2024, 17:26 -
Adobe Reader DC ver 21 won't fully print
By jyeh74 in forum ComputerReplies: 0Last Post: 7th Apr 2021, 17:43 -
Creating DVD Menus Multilingual Fully Customizable
By Chris13 in forum Authoring (DVD)Replies: 6Last Post: 6th Jan 2021, 20:44 -
fully automatic toolchain: DV -> Authored DVD
By wandmaler in forum Video ConversionReplies: 3Last Post: 18th Apr 2019, 20:10 -
Chroma Keyer in Vegas Pro doesn't fully work
By ImJustAKid in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2018, 11:26
