Hello everyone.
FFmpeg does not copy subtitles with two input files.
To convert my videos to Av1and Opus, I first use the following command to convert the video track to Av1 :
Then I use the following command to add the Av1 video track, convert the audio track from the start file to Opus and copy the subtitle track from the start file:Code:ffmpeg -i video.5.1.subfr.mkv -map 0:v:0 -pix_fmt yuv420p10le -f yuv4mpegpipe -strict -1 - | SvtAv1EncApp -i stdin --preset 6 --keyint 240 --input-depth 10 --crf 30 --rc 0 --passes 1 --film-grain 0 -b av1.ivf
Once done, I look at the video.5.1.av1.opus.subfr.mkv file with MKVToolNix Gui, there is no subtitle track.Code:ffmpeg -i av1.ivf -i video.5.1.subfr.mkv -map 0:v -map 1:a:0 -c:v copy -c:a libopus -af channelmap=channel_layout=5.1 -b:a 250k -vbr on -c:s copy video.5.1.av1.opus.mkv
After thinking about it, I wonder if I shouldn't map the subtitle track with :
-map 1:s
Or :
-map 1:s:0
positioned after :
-map 0:v -map 1:a:0
I looked at the documentation of FFmpeg on the official website but it is not clear to me at all.
I'm already converting a video track to Av1, which takes several hours so I'm asking before I'm done. If I don't get an answer by then, I'll do some tests and report the results here.
If anyone has any ideas?
Ignace.
Hello, October262.
Thank you for your quick and precise answer.
According to the link I gave myself, adapted to my case, I had to add :
Code:-map 1:s?
This will allow me to be sure that the subtitles are well copied.
Positioned after :
Code:-map 0:v -map 1:a:0
Thanks again.
Ignace. -
Hello.
Sorry, but since last night the conversion process has been stuck at 26 minutes without returning to the command prompt and therefore without an error message.
I didn't realize it until 30 minutes ago.
So I just restarted the process.
So I'll get back to you to report on the modified command test as mentioned above after the process is complete.
Thank you.
Ignace. -
That's it, the conversion of the video track to Av1 is finished.
Adding -map 1:s? to my command works perfectly.
Problem solved.
Thanks, october262.
Ignace.Last edited by ignace72; 1st Apr 2022 at 02:13.
Anonymous543Guest
Try -c:s copy command
-c:s = command for selecting codec of subtitle
copy = copies subtitle stream without rencode -
Hello, kirito.
You didn't read my first and last messages.
The piece of order you suggest is already present in my order and I indicated the piece of order that was missing, and I indicated that my problem is solved.
Ignace.
ffmpeg -force_key_frames chapters with Multiple Input Files
By koberulz in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2021, 10:02 -
thorny problem: adding subtitles to vob files in standard US DVD copy
By idatarbell in forum SubtitleReplies: 2Last Post: 23rd Dec 2020, 22:53 -
How to I nstall the FFMPEG input driver in VirtualDub?
By Avagadro1 in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2020, 00:26 -
[solved] ffmpeg -i -vn -c:a copy (clean file) on multiple files - fails
By Prototype v1.0 in forum LinuxReplies: 21Last Post: 11th Aug 2019, 03:43 -
FFMPEG or FFMBC on xdcamhd422 files: how to copy audio track4 into track2?
By marcorocchini in forum Newbie / General discussionsReplies: 11Last Post: 11th Aug 2017, 15:25
