Results 1 to 14 of 14
  1. Hi,
    while trying to download a video file I got this error:
    yt-dlp https://media.defcon.org/DEF%20CON%2020/DEF%20CON%2020%20video%20and%20slides/DEF%20CON%2020%20-%20Cutaway%20-%20Looking%20Into%20The%20Eye%20Of%20The%20Meter%20-%20Video%20and%20Slides.mp4
    [generic] DEF CON 20 - Cutaway - Looking Into The Eye Of The Meter - Video and Slides: Requesting header
    WARNING: [generic] Could not send HEAD request to https://media.defcon.org/DEF%20CON%2020/DEF%20CON%2020%20video%20and%20slides/DEF%20CO...%20Slides.mp4: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)>
    [generic] DEF CON 20 - Cutaway - Looking Into The Eye Of The Meter - Video and Slides: Downloading webpage
    ERROR: [generic] Unable to download webpage: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)> (caused by URLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)'))) (caused by URLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)')))
    What does it mean? Why do I need certification? This file can be achieved in browser.
  2. --no-check-certificate
    however there's no need for ytdlp since you can right click -> save as
    in Firefox at least.
    Weirdly it doesn't play in my Firefox but there's audio. And also, when downloaded, seeking seems to stop the video.
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  3. you have already link to your video mp4. no need yt-dlp
    put your direct link into an download manager like IDM or simply put on address bar and save as
    [Attachment 63990 - Click to enlarge]
  4. I tried another tool:
    curl -0 https://media.defcon.org/DEF%20CON%2020/DEF%20CON%2020%20video%20and%20slides/DEF%20CO...d%20Slides.mp4
    The result:
    curl: (35) schannel: next InitializeSecurityContext failed: SEC_E_ILLEGAL_MESSAGE (0x80090326) - This error usually occurs when a fatal SSL/TLS alert is received (e.g. handshake failed). More detail may be available in the Windows System event log.
    It seems the error is related to TLS. Any ideas?
  5. curl for this??
    simply click on https link with right key and "save as" ...
  6. Originally Posted by blanc View Post
    Any ideas?
    Yes, keep trying other tools.
    click click2
  7. I just wan to understand why it doesn’t work with curl, pure technically.
  8. Originally Posted by blanc View Post
    working fine here
  9. @blanc
    curl -O link
    you have used curl -0 (zero) link
  10. this was a very interesting discussion (for me at least).
    Curl worked for pkp but did not work for blanc. I checked and it did not work for me. Head scratcher.
    Fortunately for me/us pkp was kind enough (thanks pkp) to tell us the version of curl that he used.
    Curl for windows is a real mess. The version that Microsoft added to windows seems to be quite limited in it's abilities.
    For the download to work as per pkp, you need to use the version that he /she used.
  11. i think problem isn't version, but wrong command ... i have different (old version) and work already with right command:
    curl -O https://media.defcon.org/DEF%20CON%2020/DEF%20CON%2020%20video%20and%20slides/DEF%20CON%2020%20-%20Cutaway%20-%20Looking%20Into%20The%20Eye%20Of%20The%20Meter%20-%20Video%20and%20Slides.mp4
    [Attachment 64045 - Click to enlarge]
  12. thanks lomero
  13. I installed version 7.81. Guess what? It works. My old version was 7.79. Thanks guys.
