Results 1 to 14 of 14
  1. Hi there,
    I'm trying to download videos from this website www.dacast.com but I'm unable to.
    Youtube-dl & yt-dlp aren't working. It's giving me an error: "HTTP Error 400: Bad Request"
    Please help me how do I download videos from this website dacast?
    Here's the link:
    https://iframe.dacast.com/vod/2d5ebcd5-3f33-eaaa-612e-a396b7ff9ff8/3f40225b-48b3-3b5f-...2-e77835947f7a
    Thanks in advance.
  2. ,,Daily quota for free trial exceeded. Please contact us to upgrade''.
  3. Code:
    hlsdl -K "AB793E796E26B963FD114615B7FFEBA4" "https://dacast.s.llnwi.net/secure/uspaes/3f40225b-48b3-3b5f-0cf2-e77835947f7a.ism/3f40225b-48b3-3b5f-0cf2-e77835947f7a-audio=128415-video=511556.m3u8"
    Video - https://we.tl/t-fVYJa4WZYd
    hlsdl 0.27 - https://we.tl/t-DKdokjHojY
    I might have downloaded the lower resolution one.
    And that's excellent since you can try it for yourself for the bigger one.
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  4. Originally Posted by [ss]vegeta View Post
    got it...
  5. Originally Posted by [ss]vegeta View Post
    Thanks! I haven't used hlsdl before, but I'll try it.
    Is there any way to download it with Youtube-dl/ffmpeg/yt-dlp?
    Appreciate your help.
  6. Originally Posted by LZAA View Post
    It's working now, can you check?
    Thanks.
  7. Originally Posted by lomero View Post
    It's loading now, kindly check.
  8. yes, you can download each segment
    [Attachment 64018 - Click to enlarge]
    but all segment are encrypted. then need to decrypt
    hlsdl download all segments, decrypt and merge all. more easy to do
  9. hlsdl -k "keys.dacast.com" -n "keys.dacast.com/u
    spaes/3f40225b-48b3-3b5f-0cf2-e77835947f7a.key?ed53495a&ts=164
    8323249" "https://dacast.s.llnwi.net/secure/uspaes/3f40225b-48b3-3b5f-0cf2-e77835947f7a.ism/3f40
    225b-48b3-3b5f-0cf2-e77835947f7a-audio=128415-video=2040389.m3u8"
  10. Originally Posted by LZAA View Post
    same as vegeta post#5 ...
    AngelofDarkness asks:
    Originally Posted by AngelofDarkness View Post
    is there any way to download it with youtube-dl/ffmpeg/yt-dlp?
    Jun 2022
    India
    Thanks guys.
    I'm curious. How do I find that key? -K "AB793E796E26B963FD114615B7FFEBA4" to decrypt it?
    All I see in the m3u8 is server uri and IV but I don't know how to use that to decrypt the frags.
    #EXT-X-KEY:METHOD=AES-128,URI="//keys.dacast.com",IV=0x89E5C039CE1E357345FFCF3A2067 24E3
    I figured out the key server url from fiddler i.e. https://keys.dacast.com/uspaes/guid-of-the-file.key?s=xxxx&ts=1655117348
    from this I know all query params except for "s". I'm guessing thats the signature generated by the player.
    how do I get it? thats the only thing forbidding me from decrypting the video frags that I have downloaded.
    Any help or direction is useful.
    Many Thanks.
  12. Originally Posted by paapi View Post
    You need to download via network developer tools or Fiddler, the file from the URI.
    Its content in hex (can be viewed with HxD for example) is the key.
    Fiddler can prolly show it directly, it has a hex viewer I think.
    Don't be shy, post your link.
    click click2
  13. Originally Posted by LZAA View Post
    Thanks a bunch, dude! Your method was the way I was finally able to do it!
    I already downloaded my video the other way above without converting the key to a hex, but it was driving me crazy not figuring out your way. So I went back and finally figured it out. My fiddler wasn't giving me the correct response file, because I didn't have the "decrypt https traffic" setting on. With that on, I finally was able to slowly figure it out. Thank you!
    5 hours of my life well spent lol. (not sarcasm)
