When Encoding a video to a lower bitrate to make a smaller file size does it help the quality to double the Framerate? I mean doubling the Framerate does not affect the file size but does it affect quality at all?
No
At a given bitrate (thus at a given file size), doubling the framerate and doubling the number of frames (assuming you want to keep sync, otherwise it would play twice as fast, and 1/2 the running time) - will reduce the quality. Think of it as spreading more bits around more frames, thus each frame will be lower in qualityI mean doubling the Framerate does not affect the file size but does it affect quality at all?
Change/adjust framerates?
By armyofquad in forum Video ConversionReplies: 26Last Post: 30th Nov 2021, 08:11 -
Is Premiere really finnicky with framerates or is it just me?
By PCC in forum EditingReplies: 3Last Post: 23rd Mar 2019, 09:32 -
Weirdo Question: How to get SD video onto BD without re-encoding
By hotsplice in forum Authoring (Blu-ray)Replies: 3Last Post: 19th Oct 2018, 21:33 -
Framerates of interlaced footage
By CursedLemon in forum Video ConversionReplies: 3Last Post: 9th Sep 2018, 02:10 -
srestore and framerates?
By killerteengohan in forum RestorationReplies: 11Last Post: 30th Jan 2018, 19:13
