i have an mkv file which is 599mb. it's properties are:-
[Attachment 63959 - Click to enlarge]
the file size is small for a 2 hour movie and it's in good quality. i want to know how can i make a similar small sized good quality avc1 mkv file in handbrake?
Results 1 to 10 of 10
Simple. Filter out all grain and fine detail before encoding. And don't forget to start with animated material. It compresses more easily.
thanks but that's not what i asked. i know how to make a hevk mvk. i want to know how to make an avc1 mkv
Anonymous543Guest
If you are targeting small sizes then chose bitrate control and set it around 700kbps to 800kbps for 1280×720 resolution videos and for audio set around 90kbps to 128kbps it will give you good AV(audio video) quality....you can also reduce bitrates but that will decrease your AV quality but also decrease file size
You can also select presets which can improve AV quality in same bitrates but it will take more of encoding time...just like you make an zip file if you set ultrafast preset then it will give less compression and if you set slow preset and give you good compression but it will take more time
Create .ts files from a .mkv file while still recording the .mkv
By RKJ in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2020, 22:51 -
MKV to ISO Question (Blu-Ray Backup Made with MakeMKV)
By mugz8391 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2020, 13:44 -
How to extract audio track of .avi file to include it in a .mkv file?
By nickiman in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2019, 07:15 -
Inserting one .mkv file into the middle of another .mkv file
By Cinderwolf in forum EditingReplies: 4Last Post: 29th Dec 2017, 17:48 -
Merging MKV extracted files to playable MKV video file
By deepfrayder in forum EditingReplies: 9Last Post: 13th Dec 2017, 00:17
