  1. I capture with Miro dc30+,I save as avi,then I convert to mpeg1 with TMPGEnc,but the vcd Creeator wont open that file it all.
    please help.
    Rigo.F
  2. Banned
    Jun 2001
    UK
    Did you "Load" a template before you hit start
    template for VCD-PAL or VCD-NTSC
  3. do you mean in TMPGEnc or vcdCreator?
    I convert the avi file to mpeg1 with TMPGEnc,then when I try it to burn on a cd as vcd using VCDcreator wont let me open it,said something like,,this file wont play in a vcd player...and VCD creator don't show any video file either...
    when I rip a dvd work fine but when I want to make a vcd from a family video the VCD creator don't show any video file....
    Rigo.F
  4. Y tried with Nero and work just fine,I wonder why don't work with VCD Creator...
    thanks.
    Rigo.F
  5. Banned
    Jun 2001
    UK
    When you load the AVI into TMPGEnc, before you start to convert you need to "load" a template, the tamplate will set TMPGENc to make the VCD with the correct spec.
    Hit the load button and select a PAL or NTSC VCD template.
