I trie to rip a dvd with Tencoder. It works fine but I have no sound.
Please help.![]()
Results 1 to 28 of 28
If you tried to play it on an older tv/media player then it won't have sound due to the device not equipped to play ac3 sound.
Yes, on top of that, this program seems buggy to me
Try choosing mp3 as your audio -
Aac would be a better choice for audio.
I've tried to play it with VLC en mpc-hc. No sound. I play it on my PC windows 11.
I have already ripped de DVD with Vidcoder. That works fine and no sound problems.
But It is ripped to mp4. So I tried to convert it to avi with Tencoder and it works, but again "without" sound.
Now, it's not a big problem. I can rip with many other programs. I only tried for the first time to do it with Tencoder.
I only was curious to the results and now I have an answer: it doen's works perfect! The movie is ok but the sound not.
Thanks for your support.
Then both it and you are using the term incorrectly. Get as far away from that program as you can. I guess you proved that for yourself already as using 2 other programs produced both playable video and audio.
And as davexnet already mentioned, it really had audio. For future cases you might install the AC3Filter. -
Yes, I tried it myself on an old region 2 DVD "Thunderbirds" (1960's Supermarionation),
this program can rip protected DVDs. I'd looked at it once or twice in the past but never
noticed it before.
My xvid/mp3 Avi came out fine. One thing I did notice, once you pick the title,
It allows you to select the chapters, but I could not get this functionally to work
the program rendered the full title and ignored my setting for chapters
1-2 only -
Indeed, the combination Xvid with mp3 works also fine. However combinations Xvid or H264 with AC3 give no sound.
Going back in time to about 2005, xvid/mp3 was the usual combination for 700mb CD movie AVI rips.
AC3 should work fine in avi, this must be a bug in the program
For H264/aac stick to MP4 or MKV containers -
Trying again to rip with Xvid and AC3 after I had installed "ac3filter_1_62b_lite" it gave No Sound. So I give up with trying AC3 and keep the fine working combinations higher mentioned.
I accept you now have a working solution. But there still has to be a reason why audio when reported does not play.
Consider these two encodes from the same source. Both claim to have audio yet only the 2nd one, with a larger file size (which I assume is the actual audio track) plays sound -
I inferred to that above.
The video header, which mediainfo reads, claims an audio track as prepared by Mencoder (the actual encoder). Yet, for whatever reason (someone with more knowledge of how encoders work might have some ideas) it has not been written in to the actual avi stream.
Whereas when the same source was written to with ffmpeg the audio track was written in to the stream.
It's probably a 'bug' within Mencoder itself or that ac3 is not actually implemeneted at that time. Tencoder is not the most uptodate program and the encoder versions are also quite old - ffmpeg from 2015 amd mencoder even older. -
I thank you for your interest and trying to help me. Against a bug in the program is no help possible. So, as I told before I keep my working combinations.
Since today I had no problems by ripping with TEncoder. Now it works no longer. Convertion options still works. I've tried several times, but no result by ripping. I gave permission on my spam scanner for TEncoder en FFMPEG but no use. I've tried in mencoder and in ffmpeg position but no result. Every time I tried to rip, after the input of the to do file, immediately I hear the bell ringing, but without a result. What is happening?
Adding new fonts to TEncoder
By roancat in forum SubtitleReplies: 0Last Post: 2nd Feb 2022, 07:25 -
Ripping from DVD to MKV- Which audio option do I choose?
By JDMils in forum DVD RippingReplies: 4Last Post: 14th Jun 2021, 11:35 -
Ripping a DVD Audio disc into WAV or FLAC
By efiste2 in forum AudioReplies: 2Last Post: 15th Nov 2020, 10:59 -
TEncoder x265 problem
By rocksam in forum Video ConversionReplies: 11Last Post: 1st Nov 2019, 10:11 -
Question about TEncoder
By TheRandomOne in forum Video ConversionReplies: 1Last Post: 22nd Feb 2018, 11:54
