Hello... i got a movie in 2 dat files.
about 450mb each.
Have way to join it and choose the final size of the file ??
I want burn it in a 700mb CD.
Thank you very much
Well the answer to your question is written right in the guides.
Use vcdgear to convert the dats to mpgs. Use TMPGenc to join the mpgs. VCDCutter will do better job of joining but its not free, so TMPGenc is the best free tool for the job.
You can't change filesize without re-encoding. If you want to squeeze those mpgs onto a single 80 min cdr then get a bitrate calculator from the tools section and it will tell you what bitrate to use. -
As above, use VCDGear to convert back to standard MPEG first.
I'm generally against joining MPEG files and I don't believe that there is a place for it. Rather than joining it, why not just put both MPEGs as separate tracks on a VCD?
Although the gap between the two mpegs will be larger if you use two separate tracks, the result in joining them can often be that there is an audio blip -- or perhaps even A/V sync problems.
As for the size of your files, you will not be able to put them on one 80 min CD without re-encoding to a lower bitrate (losing quality significantly and probably making your discs non-compliant).
You may be able to fit both on a VCD if you use 90/99 min media, however.
Regards.Michael Tam
w: Morsels of Evidence -
Ohhh thanks to the great tips !
I have only a little about the last reply, here in brazil i dont have a place to buy VCD 90/99min, i dont was know it exists :P Now i know... how about the price of one blank VCD there ?? and can i burn it in a single CD write ??
Thank you very much !!!
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
