this is the media info. there is Title under "Video" section, is there anyway we can batch replace the title with something else. i found batch script to edit the title under "General" section using mkvpropedit.exe
Code:General Complete name : File.mkv Format : Matroska Format version : Version 4 File size : 672 MiB Duration : 21 min 35 s Overall bit rate : 4 352 kb/s Writing application : Lavf58.76.100 Writing library : Lavf58.76.100 ErrorDetectionType : Per level 1 Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 21 min 35 s Bit rate : 23.8 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.479 Stream size : 3.59 GiB Title : .................VIDEO TITLE I WANT TO EDIT............................. Writing library : Lavc58.134.100 libx265 Default : Yes Forced : No Color range : Full colour_range_Original : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Original source medium : Blu-ray Audio ID : 2 ID in the original source medium : 4352 (0x1100) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 21 min 35 s Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 548 MiB (82%) Title : DTS-HD MA 5.1 Writing library : Lavc58.134.100 ac3 Language : English Service kind : Complete Main Default : Yes Forced : No Original source medium : Blu-ray Text ID : 3 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 21 min 27 s Bit rate : 78.6 kb/s Count of elements : 1080 Stream size : 12.0 MiB (2%) Title : English (SDH) Language : English Default : Yes Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : :Chapter 01 00:06:40.149 : :Chapter 02 00:13:17.421 : :Chapter 03 00:18:27.815 : :Chapter 04 00:20:56.004 : :Chapter 05
Results 1 to 1 of 1
Batch Script for mux mp4 to mkv using mkvmerge
By iKron in forum Newbie / General discussionsReplies: 5Last Post: 25th Aug 2025, 15:18 -
How to change MKV file comment and title using batch script?
By iKron in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2021, 07:05 -
How to edit title of mkv file
By iKron in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2020, 04:44 -
How can i edit this script to batch mux chapters with MkvToolsNix
By Red_Rain77 in forum Newbie / General discussionsReplies: 0Last Post: 25th Aug 2019, 20:20 -
Batch MKV title to filename renaming.
By Zareaus in forum Newbie / General discussionsReplies: 7Last Post: 16th May 2018, 04:12
