Hi.
I'm looking for a .bat script that will decrypt video and audio (mp4, m4a) using keys stored in a txt file.
I came across sth like this:
The above script is not too good because it runs each key separately and creates redundant files. So If I have 20 keys in txt, the will script create 20 videos (one decrypted among them).Code:setlocal enabledelayedexpansion for /f "delims=" %%a in ('dir /B *.mp4') do ( set /a counter=0 for /f "delims=" %%b in (keys.txt) do ( set /a counter+=1 mp4decrypt --key %%b --show-progress "%%a" "%%~na_!Counter!.mp4" ) )
Can you guys come up with sth better?
Results 1 to 14 of 14
put on same folder key.txt, mp4decrypt, decrypt.bat, video.mp4, audio.aac, ffmpeg
audio and video are encrypted
edit key.txt with your key:
edit decrypt.bat with:Code:video,xxxx:xxxx audio,xxxx:xxxx
create new bat join_audio_video_ffmpeg.batCode:@echo off pushd "%~dp0" md ".\decode" >nul 2>nul for /f "tokens=1,2 delims=," %%a in (key.txt) do ( for %%c in (mp4 aac) do ( if exist ".\%%a.%%c" ( mp4decrypt.exe --key %%b "%%a.%%c" "____tmp.%%c" move /y ".\____tmp.%%c" ".\Decode\%%a.%%c" ) if exist ".\%%a(Audio).%%c" ( mp4decrypt.exe --key %%b "%%a(Audio).%%c" "____tmp.%%c" move /y ".\____tmp.%%c" ".\Decode\%%a(Audio).%%c" ) ) ) echo,ok pause>nul
Code:echo off ffmpeg.exe -i ..Decode\video.mp4 -i --Decode\audio.aac -c copy muxed.mp4
Doesn't work.
Besides my keys txt file looks like this:
I don't know which key is correct so I need the script to find it out.Code:0100c6ff9e3c64f14ba77e3bbb6a82dc:20bc0db1734e4a368af98f8340cc37c6 0105e2531122ec62ae1adbfcd2d30e84:3787f7c1fbbc8b6494e3411ddeae23a3 010280d0df7acf79502606dc4fd1ec46:4d7519e64031a171a01422fb84a7b6fe 01011b0127298b4a0ffb2862b321aca7:b9bfd3f6417f902ce8fd6899fbb210b5
mp4decrypt does that automatically.Last edited by m0ck; 14th Mar 2022 at 12:49.
If python is ok this can be achieved easily.....
keys.txt
test.pyCode:eb676abbcb345e96bbcf616630f1a3da:100b6c20940f779a4589152b57d2dacb 0294b9599d755de2bbf0fdca3fa5eab7:3bda2f40344c7def614227b9c0f03e26 639da80cf23b55f3b8cab3f64cfa5df6:229f5f29b643e203004b30c4eaf348f4
Set the path of mp4decrypt,video input and output according to your needs..If you want to fully automate pass the kid from your script instead of manually enteringCode:import subprocess kid = input('Enter the KID:') with open('keys.txt') as f: for line in f: stripped = line.strip() if stripped[0:32] == kid: key = stripped[-32:] key_pair = kid+':'+key #print(key_pair) subprocess.run([mp4decrypt, "--key", str(key_pair),"video_encrypted.mp4","video_decrypted.mp4"]) -
yes not work. for you. look better my key.txt:
video,kid:keyCode:video,xxxx:xxxx audio,xxxx:xxxx
and same for audio. replace kid:key with your data like 0105e2531122ec62ae1adbfcd2d30e84:3787f7c1fbbc8b649 4e3411ddeae23a3
but need video, first where video, is the name of your video file encrypted.
if you don't follow this syntax the command does not work -
But as I said, I don't know which key is for video and which is for audio and keys txt contains lots of keys so unfortunately your script won't do in my case.
do you know the kid for the video and audio?
if not, you can get it from the video/audio file with mp4dump.
(alot of smaller streaming sites only use the one kid per content)
eg.
that way you can pkp's script which finds the line with the kid in the key.txt file and uses the kid:key in the decryption.Code:mp4dump <encrypted_file> | findstr /I kid default_KID = [59 d5 c7 a1 e3 6d 1c d7 0c b7 4c 51 ca b5 ac e1]
the other way is to add all the kid:keys to the mp4decrypt command and it will use the one that matches the kid of the file.
ie.
Code:mp4decrypt --key <kid1:key1> --key <kid2:key2> --key <kid3:key3> --key <kid4:key4> --key <kid5:key5> <encrypted_filename> <decrypted_filename>
That is EXACTLY what I want to achieve. But instead of copying each key to the command line, I want the script to take them from txt file.
That's all.
Concept:
mp4decrypt --key keys.txt encrypted.mp4 decrypted.mp4
In keys.txt thare might be lots of different keys and only one is correct (don't know which).
Is sth like this even possible in batch script? -
This is what you are looking for
Code:@echo off :start setlocal enableextensions enabledelayedexpansion echo. set dec=dec.mp4 set enc=enc.mp4 for /f "delims=" %%a in (keys.txt) do ( set /a totalKeys += 1 set "keys=!keys! --key %%a" ) echo Found total %totalKeys% keys :decrypt_process set mp4dec_args="mp4decrypt.exe" --show-progress !keys! "!enc!" "!dec!" echo MP4DECRYPT ARGUMENTS & echo !mp4dec_args! & echo. !mp4dec_args! echo. endlocal pause
@zackmark29 This is AWESOME and exactly waht I was looking for!
Thanks a ton!
One more thing though.
How to change the script to also decrypt audio?
There are two files in a folder.
encrypted.mp4 (video) and encrypted.m4a (audio) -
@echo off :start setlocal enableextensions enabledelayedexpansion echo. set enc_v=enc_v.mp4 set dec_v=dec_v.mp4 set enc_a=enc_a.m4a set dec_a=dec_a.m4a for /f "delims=" %%a in (keys.txt) do ( set /a totalKeys += 1 set "keys=!keys! --key %%a" ) echo Found total %totalKeys% keys :decrypt_process echo DECRYPTING VIDEO TRACK mp4decrypt.exe --show-progress !keys! "!enc_v!" "!dec_v!" echo. echo DECRYPTING AUDIO TRACK mp4decrypt.exe --show-progress !keys! "!enc_a!" "!dec_a!" echo. endlocal pause
hi there, batch script from @zackmark29 is awesome and work perfectly but i want more comfortable to use
i've read this thread from @A_n_g_e_l_a (thank for your python) and i see the way to improve zackmark script "Copy stream URL as 'Table Entry' from The Stream Detector"
read keys from key.txt and use Table Entry for set a filename and MPD_URL (using with N_m3u8DL-RE)
i try to implement zackmark batch script but it gave me more error when query string from Table Entry to filename , mpdurl , timestamp
can anyone help me ? thanks a lot.Last edited by Biggy4; 14th Feb 2023 at 11:05. Reason: typo
Got keys but can't get encrypted video. Please help
By daigo99 in forum Video Streaming DownloadingReplies: 7Last Post: 28th Oct 2022, 03:28 -
How to decrypt webm video file?
By webcyb in forum Video Streaming DownloadingReplies: 3Last Post: 25th Oct 2021, 05:01 -
decrypting the video with keys
By jamkiya in forum Video Streaming DownloadingReplies: 4Last Post: 30th Aug 2021, 03:11 -
Decrypt HLS on demand video file
By shock in forum Video Streaming DownloadingReplies: 9Last Post: 6th Nov 2019, 09:42 -
Luma value in a TXT file
By barabba2005 in forum Video ConversionReplies: 6Last Post: 17th Nov 2017, 11:34
