Results 1 to 10 of 10
  1. I am currently developing the Windows mgns Video Transcoder.
    The tool is created for encoding by AOM-AV1 (or x264) codec to target size with constant quality.
    The tool also can do semi-automatic resolution selection at encode stage.
    It can be downloaded from sourceforge
  2. Out of curiousity: What do you does 'semi-automatic resolution selection at encode stage' do?
  3. Originally Posted by Selur View Post
    From documentation (mgns/VideoTranscoder/codecs/transcode.md):
    The algorithm consists from following phases:
    • split video file to chunks, respecting scenes boundary
    • transcode the chunks with constant quality with origin resolution
    • select most appropriate chunk
    • encode the chunk with different resolutions but same target size
    • calculate metric for each resolution and select resolution with highest metric
    semi-automatic means "select most appropriate chunk" step is performed by a human.
  4. Ah, okay. Thanks for clearing that up.
  5. v1.1.0 is released.
    changelog:
    fixed: deadlock
    fixed: avc concatenation
    speed up: encode restarting time was decreased after unexpected stop
    speed up: avc encoding speed is improved by descreasing crf level step (current crf level steps: 0.1 for x264 and 1 for av1).
    speed up: segmented encode: true middle+uniform encode order is used now.
    new: showVersion.cmd fast util was added
    changed: install documentation
  6. mgnsVideoTranscoder v1.2.0 is released.
    changelog:
    * Error description on process creation failure is improved.
    * AOM AV1 respects --lag-in-frames parameter for memory consumption detection.
    * AOM AV1 encoder params are added: --lag-in-frames --enable-qm --enable-fwd-kf
    * user friendly printing of display aspect ratio for media info getting.
    * big example was changed by a small example (mgnsVideoTranscoder package size now is 128 MiB)
  7. New version is released 2022-03-30 v1.3.0.
    Changelog:
    • documents are generated as html in "docs" folder
    • mkvtoolnix was updated to 66.0.0
    • aomenc: crash workaround at low --cq-level
    • aomenc: "--enable-keyframe-filtering=2" support.
    • presentation timestamps getting speed is improved for matroska file
    • aomenc params are added: --aq-mode, --kf-max-dist, --kf-min-dist, --sb-size, --enable-keyframe-filtering, --arnr-strength, --arnr-maxframes, --enable-restoration, --deltaq-mode, --sharpness, --enable-dnl-denoising, --denoise-noise-level
    • was updated to ffmpeg-5.0
    • no more need to rename setLocalPaths.template.cmd
    • isVideosEqual feature is uncovered
  8. New version is released 2022-04-06 v1.4.0.
    Changelog:
    • aomenc: most of raw params are added.
    • download mirrors were added.
    • automatic keyframe interval is added (max 300 frames, or 10 seconds)
    • encode chunk size is increased. minimum size is keyframe interval.
    • hdr support: MasteringDisplayInfo and ContentLightLevelInfo were added
    • fixed: 8K resolution unwanted disk IO was removed during encoder memory detection.
    • fixed: pipes IO
  9. New version is released 2022-04-08 v1.4.1.
    Changelog:
    • ffmpeg was updated to ffmpeg-5.0.1
    • broken download links were fixed
  10. New version is released
    (2022-09-24) [v1.5.0]
    * aomenc was updated to v3.4.0
    * vmaf was updated to 2.3.1
    * ffmpeg was updated to 5.1.1
    * x264 was updated to r3098
    * documentation minor fixes
    * error handling is improved
    * codec name AOM_AV1 was changed to aom_Av1
    * codec name AVCEncoder was changed to avc_x264
