Upon purchasing this AG-1980P a few months ago it ejected a couple tapes and then always played every tape there after. I have now played and converted 17 tapes and it has operated perfectly (except a whistleing sound in rewind), but again always plays perfectly. Suddenly sitting down to use today it ejects every tape I insert. I opened it up and it appears to take the tape to play but after a few seconds ejects every tape inserted. I used to be small time circut board level electronic technician but I am too afraid to mess with this since I have never worked on a VCR and I assume it is probably a mechanical problem. I have attached a video. If anyone has an idea if I can fix this. Otherwise I may not attempt in fear of doing damage.
PS: I only have 10 more 20 minute tapes to convert, after that all I want to do is sell this unit.
Sounds like a loose or broken capstan belt,look on the bottom to see if it's that way.
I am trying to figure out exactly where that is located I am not seeing a place for the belt. I know it's very visable in some vcr's, but I am not seeing it.
Take off the bottom plate of the vcr,
You probably need forum member/user deter, and about $500.
Just let him fix this.Want my help? Ask here! (not via PM!)
You know how many people mistaken this subforum for "VCR player" instead of "VR player"?
Anyway, that needs to be taken apart and operate the mechanism manualy through all its satges to see what is blocking it, If it passes the mechanical test it could be a mode switch, If this is above your head it means you will need to pay someone to fix it or send the remaining tapes to a qualified transfer service.
Deter's AG-1980 Repair Service
By Deter in forum RestorationReplies: 190Last Post: 28th Jun 2025, 20:45 -
VCT tape video capture: Tape shows annoying VCR Speed and Tracking bar...
By MoonView in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2021, 22:52 -
VHS player ejecting cassettes immediately and tape not being released
By itm2 in forum RestorationReplies: 3Last Post: 23rd Aug 2020, 15:49 -
VCR immediately ejects tape.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 31st Jan 2019, 19:24 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 08:14
