Quetion i got a the MOvie spiderman on a DVD-R but it wont play on my DVD standalone player it tells me its not NTSC so im guessing its PAL is there any prog i can use to convert it. It plays on my DVD-RW so i know the movie is there, Also the first 20 minutes of the movie there is lots of blocks on the top and bottom is there a way i can fix that?
can any one give me any suggestions??? pleasee any help will do ............Thnx
What type of file name/extension does it have when you check it on your DVD-RW?
Other alternative wouls be to download the SVCD Centropy Spiderman that is on the newsgroups at the minute? Then join the MPG's and write to DVDR?
Not sure about any other ways. Sorry. -
I don't have it in front of me, but I believe the Centropy SVCD Telesynch IS in PAL
I know it was 25 fps with a 2500 vbr. I can't recall the dimensions.
You may want to check to the left under CONVERSION and look at PAL -> NTSC Conversions.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
http://www.vcdhelp.com/pal2ntsc/pal2ntsc.htm
For VCD, but you'll get the picture~~~Spidey~~~
Well my dvd-r has 2 folders the VIDEO_TS and audio on the video i have the vob files how can i go about to fixing them ?what software? or converting them ?
hey email me the location to obtain this movie.
ygreene@houston.rr.com
be a pal share.
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 00:23
