Results 31 to 58 of 58
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
I always hesitate to dispense with something that could prove useful somewhere down the line, even if the odds on that may be remote. Because you never know. (I mean, I still have occasional uses for programs like DVDVob2MPG.) In that spirit, I wanted to reinstate this program onto a software-rather-well-equipped Win-10 system. And to see if I could get it operational again. I went searching thru old storage, encompassing a few old out-of-service computers and backups from them. I found a couple iterations of this Womble MPEG Wizard DVD. One was in the form of an installed folder of program files, which I transferred to this computer. Now in my admittedly hazy recollection, this little maneuver almost never works. There may be things that had to get put into the OS Registry at time of install -- or Who knows What. But I clicked on the program executable, and to my great surprise the program launched ! However, that iteration turns out to be version 4.
But I also found a couple installer files for version 5. One was from an old GiveAwayoftheDay promo. Those are nearly always time-limited to the duration of the giveaway, so > 90% of the time they will not work thereafter. That is to say, the given Regkey for it. Finally, I found what must be a copy of the Version 5 Trial installation file, which I think is probably the same one that Baldrick just re-linked. But I have no Regkey for it. Back in the day, I might have found this online, but my 'Go To' sites for that are no more. Seeing as the product and the company are defunct, I think this ought to render copyright issues null and void. (?) At least, that's how I see it. If anyone has a valid version 5 key they'd like to share, please PM me. Otherwise, I'll just have to settle for that apparently still working version 4.
[EDIT: I also found a folder of installed files for an earlier, "Junior" product from the Womble lineup: Easy VCR (?) It could be that that one still launches too, though I've not tested it. Just out of curiosity, did that program do anything useful that was not later adopted and incorporated into their MPEG Video Wizard DVD ?]
[EDIT #2: Incidentally, what I use that DVDVOB2MPG for: I sometimes have VRO files from DVD-RAM discs, used to get material off of my Pio DVDRs, and then need to convert them to MPEG. It may be that some other software I have can also do this -- maybe something like Cyberlink Director or the Nero suite ? -- but if so I either never knew it, or have forgotten. DVDVOB2MPG is itself the successor to some prior program, but works quite well for this. A lot of past programs have some capacity or other that can still come in handy. Which can be where a software repository like the one here on VH becomes so valuable.]Last edited by Seeker47; 3rd Jan 2025 at 07:11.
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
I'm running Win 10 x64 at latest 22H2 level, and not seeing problems so far on the restored-from-old-storage MPEG Video Wizard DVD. Except that a couple of the buttons at left on the "floating bar" keep flashing, and don't seem to be operable -- whatever they were supposed to be for. Haven't had to resort to Compatibility Mode to launch the program though. If / When there were problems, I thought that effective workarounds had been published in threads here ?
I love this program, very easy to use. First I used it in Windows 7, still using with Win11.
If only we had its source code and someone continued to develop it! -
There are more than a few programs -- in various categories -- that had some unique feature(s) &/or ease of use, which have never been surpassed or replaced with an equally-good alternative. So we have the incentive to keep them available for use for as long as possible. If that requires running them in compatibility mode, or running them in the VM of an earlier OS, then so be it.
I use 64 bit Win 11 Pro with LAV Filters installed, with D3D11 video acceleration enabled in LAV's settings.
Using the latest Womble release 5.0.1.112 - set to start in Windows 7/8 compatibility mode.
I get black screen for H264 videos. How to fix it?
I have no problem with VP9, H265, AV1 encoded files:
[Attachment 85889 - Click to enlarge]
I only have problem with H264 encoded files. I get no preview for them on the second preview window, on the right side:
[Attachment 85890 - Click to enlarge]Last edited by ridibunda; 3rd Mar 2025 at 01:14. Reason: screenshots
I don't know the answer to this, but as a practical matter you might be forced into the solution I use for playback on some of the many varied video format files that I work with. My preferred playback device balks at playing certain files, for codec support reasons. So, if I want to view them via that playback device (feeding the bigscreen tv), I'll have to first convert the file to another video format. This generally works. The converters that I have liked are Win-X Converter from Digiarty, and the fairly parallel one from Wonderfox. But there are others to choose from. Possibly even others that are free.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
To be more clear: The second window/output window on Womble is where you can watch your edited video before extracting it, where you can see if your new audio is synched with your video, etc, etc... So, if you can't get a preview there, you can't do any video/audio editing (not talking about the window on the left/input window, every file can be opened there but it is not used for editing processes)
I tried everything on LAV Filters video configuration: Disabling HW acceleration, choosing DXVA2, choosing D3D11, choosing NVIDIA, it didn't matter.
I tried a program called Win7DSFilterTweaker ; I chose "LAV Video" instead of "Microsoft" for the decoding of H264 files, it didn't matter again.
There was always black screen on H264 previews! And sometimes, crashes and shutting downs for H264-encoded files (in MP4 container).
Finally, I tried changing file extension, renaming those "mp4" files as "mpg" files. And it is solved! Now, previews are active and no crashes.
As far as I understand, this is not a decoding issue but a container issue. A problem about LAV Splitter, but I see no setting to solve it.
It's very weird to experience it with an old video format-H264, not with the newer formats like HEVC or AV1.
For H264-encoded files, changing the MP4 extension to MPG solves the problem:
[Attachment 85896 - Click to enlarge] -
If I set "LAV Video" as H264 decoder instead of "Microsoft" (using Win7DSFilterTweaker) and if I change the file extensions from "mp4" to "mpg" or "mkv", I get no errors on such files... If I don't change MP4 file extensions, Womble crashes!
Very interestingly, I saw no problem for H264-MKV files, just for H264-MP4 files.
I see, the issue is not related with compatibility mode or anything else. An interesting container problem.Last edited by ridibunda; 3rd Mar 2025 at 06:45.
What is your graphics processor? Installing K-Lite Codec Pack Basic didn't change anything for me. It is just a combination of LAV Filters package, Codec Tweak Tool and Direct Vob Sub anyway.
And, even I get the preview I mention, if I fast forward the video, the audio gets out of synch. I never experienced these issues before on Windows 7 and Windows 10 with older processors. Very weird.Last edited by ridibunda; 4th Mar 2025 at 01:33.
That was also my previous graphics which I had no problems. Now I have Arc graphics (the latest driver installed).
I don't know what's really going on inside, I guess there's something wrong about splitter or/and renderer, as a result I can't properly play videos on Womble's output window. Even I manage to get previews, audio gets out of synch if I skip video just a little bit forward.
Edit... Today's efforts:
1- Checked all of the recommended "use MERIT" options in "preferred decoders" section in Win7DSFilterTweaker
2- Converted MP4 containers to MKV with MKVToolnix (I understood that changing the file extension directly causes those sync problems)
3- Saw that preview errors and synch errors are gone.
But now I have the exporting problem. I can edit my video via Output window but Womble crashes when I try to export my edited file.Last edited by ridibunda; 4th Mar 2025 at 07:30. Reason: export problem
I installed x264vfw codec, same result again, Womble crashes before exporting.
Does anyone know a very similar, basic and functional program?
I'm not interested in confusing programs like Adobe Premiere. -
As I experienced in my case (with Intel Arc graphics), Womble can only be used for standard definition video files like VOB/MPG/MPEG formats for which Womble offers a direct stream copy option.
But it can't be used with AVC or HEVC videos. Womble does not offer a direct stream copy option for those and it won't re-encode your edited video - you have a crash in the end (doesn't matter which codec pack you install)
No problem with audio files.
Yes, Womble works but without a full functionality. So, I made a search (nobody helps in this forum) and decided to use OpenShot Video Editor, the most similar program to Womble.
From now on, I'm using Openshot for HD videos, Womble for the rest (Because of Womble's no-reencode options).
Openshot does not offer a direct stream copy option but my processor does very fast encoding, like 200-250 frames per second for HD videos, so that's not an issue for me.
Good luck to everyone facing the same problem. I couldn't find any better solution. -
There are reasons for all of that.
For one thing, the final version of Womble MPEG Video Wizard DVD was released in 2015. That is why Womble MPEG Video Wizard DVD only supports importing MPEG-2 and a few other older video formats that were popular up until the mid-2010s. In 2015 AVC was becoming known to the general public but was mostly used for high definition resolution video so Womble MPEG Video Wizard DVD's support for it was poor. The first HEVC encoder was released in 2013 but the general public knew nothing about it in 2015. Plus, watching HEVC video was nearly impossible at that time.
Also, since Womble MPEG Video Wizard DVD's purpose was to export DVD-compatible video, it exports standard definition MPEG-2. (The DVD standard only supports MPEG-1 and MPEG-2 video but MPEG-2 had greater popularity.)
You have to move on to a new editor to get the features that you want. Videohelp has a software section with information about many video editors. If you must use free editing software, I don't have enough experience with that to provide recommendations for you. However, if you are willing to pay, most of the paid editors have a free trial period so you can try before you buy. TMPGEnc MPEG Smart Renderer might be worth a look.Last edited by usually_quiet; 13th Mar 2025 at 13:28.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
The thing is, Womble works perfectly with Intel HD and UHD graphics, but not with the newer Intel Arc graphics.
In my case, I see that Womble does not even support hardware video acceleration/decoding. When I load a HEVC UHD video to Womble's output window and look at my LAV Video screen, I see "avcodec" in charge without HW acceleration (It should have been "dxva2" or "d3d11" active codec with a graphics acceleration)
In other programs, like SmartDVB, I see Dxva2 HW acceleration enabled in LAV's screen, but not with Womble... Some people say "Arc has a different engine", maybe that's why it is unable to recognize Womble, I don't know... I can play 20 year-old video games but I can't use a Womble from 2015, very weird.
[Attachment 86092 - Click to enlarge] -
Two years ago I bought a Lenovo Thinkpad P1 Gen5 Windows 10 pc (my first Win10). It has Intel Iris XE integrated graphics. I was frustrated to find that on the new pc Womble MPEG Video Wizard DVD would instantly crash upon importing an H264 mp4 file. I have looked intermittently for a fix since then, which led me to many of the same dead-ends others cite, especially @ridibunda (including the "trick" of renaming mp4 to mkv in input-file extensions, as well as in the wbp project files -- which are basically just simple plain text parameters).
As an experiment, I had even tried removing the chip from one of the two memory channels, which -- as per Lenovo documentation -- automatically converts Intel Iris Xe into Intel UHD. (Windows confirmed this.) But that didn't help in any way.
I was about to conclude that Intel Iris Xe wouldn't play nice with mp4 in Womble 5 no matter what, and I would have to throw in the towel.
But then last night I tried something simple. And Eureka, it worked
!! In the UEFI BIOS I went to Config -> CPU -> Intel Hyper-threading technology, and switched it from on to OFF.
That simple change solved it. Now the H264 mp4's load, smooth as silk. And everything renders as expected (including as H264 MP4), and without a crash at the end. No visible instability thus far. As indicated by the tray icons, Womble is using LAV to decode the H264 mp4's. -
This setting cannot work. Disable the HW acceleration.
[Attachment 89830 - Click to enlarge]
My working settings:
[Attachment 89831 - Click to enlarge]Last edited by ProWo; 21st Nov 2025 at 07:32.
If a piece of software still retains any utility for us, I hate seeing it rendered inoperable later on, for no good reason. There has been a drift towards the companies deciding this to lock down the hardware and the OS ever further. I'm a major non-fan of UEFI, Secure Boot, and TPM 2.0, which are all efforts to do this, and it's partly why I continue using computers that predate them. That certainly includes avoiding Win-11, whose hardware requirements these older rigs do not meet. These added layers of "security" are things I have no need of. In fact, they are just stumbling blocks that get in the way of things I want or need to do. On the older computers I can easily boot (in from outside, with nothing locked by Windows) via CD, DVD, external HDD, or USB stick. We do have a couple more contemporary desktop systems at our office. In the past, when I attempted to do an image backup of the boot partition, UEFI (or maybe Secureboot, or maybe both ?) totally blocked this ! The only option was to go into the BIOS and temporarily reset to Legacy Mode -- ignoring some dire warnings (from Dell, or whoever the mfr. was) that one really should not do this. But I proceeded anyway, because such backups comprise important insurance against disaster. After the backup procedure, the BIOS must be returned to the default UEFI mode. What a colossal Pain in the Rear ! I never have to deal with that on my home rigs, where it's just a clean, straight shot.
Someone a lot more tech-accomplished than I am suggested that this was a fault due to using older software versions for the imaging. But I'm very skeptical, and think this advice was incorrect. I think that if I tried a current version of Acronis TI, Macrium Reflect, or any of a couple other very capable imaging solutions that I've used in the past, they would not be able to neatly jump over this obstacle, but would instead smack right into this same brick wall, sliding down with a thud. And UEFI is pretty ubiquitous these days, likely impossible to avoid.
And what happens if the powers that be, in their great wisdom, decide to do away with any Legacy Mode in the BIOS ? (The next shoe to drop, so to speak.) You wouldn't shock me if you told me that this has already happened !
So, there are some alleged "improvements" in tech to which I continue to say "NO THANKS !"Last edited by Seeker47; 21st Nov 2025 at 19:09.
(Caution: Mostly OT rant.)
I hear you, @seeker47! It seems as if for every bona fide improvement in features or performance (and there have admittedly been quite a few), we take two or three steps backward. Things that used to be easy to accomplish become harder. In Windows 10 I have to dig and tweak and jump through hoops to do things that were easy in Win 7. Just something as simple as font adjustments have been made harder with the newest Windows 10 feature releases. Some useful capabilities which were deprecated in 10 are now completely gone in 11. It used to be easy in to get into Safe Mode by rebooting and pressing F8 repeatedly. But now -- even though there are multiple methods -- you have to go through a series of steps. Now you can't even reboot into the BIOS without disabling silly "Fast Start" first.
And as for hardware...on my older Thinkpad laptop it was easy to replace a keyboard if needed. With my newer Thinkpad I wouldn't even attempt it, because it basically requires disassembling the whole machine. It used to a snap (literally) to pull out a battery, and to replace it. But now it requires removing the cover and uninstalling it. Of course smartphone batteries switched to non-user-removable years ago. And so much of this inconvenience is just to meet current aesthetics: It MUST be cracker thin! And no bezel! (Which means that without additional sound accessories, I won't hear stereo from my TV unless I stand behind it.) OK, end of rant.
I'm just glad I finally got Womble to work with mp4's again on my newer Thinkpad. And maybe I don't fully understand, but what do I need virtual CPU threads for when I've already got 14 cores?? And BTW, I read Intel announced not long ago that they would get rid of hyperthreading. Then abruptly decided to keep it. Whatever.Last edited by Rick612; 25th Nov 2025 at 17:34. Reason: misspelling
@Rick612,
I'm in lockstep with you on all of your comments. Several cell phones ago, I used to always have a spare, user-swappable battery charging, ready to switch in. So very convenient ! The charger was this metal, spider-arm kludgey gizmo, but it worked. Hardly any cell batteries last long enough these days, before their too-rapid depletion. Progress ? NOT !
Win 7 was the best (some plausible arguments there for XP), 10 a marginally acceptable downgrade. Users became a mere commodity, one for them to harvest. At the cost of our security and independence. Supremely irksome, the way they feel some compulsion to change the names and locations of so many key OS items, upon each new version. Put on that blindfold, and stumble your way forward, with much inefficiency and waste of your time.
That imaging issue snafu I mentioned is a very serious matter however, for anyone interested in keeping good precautions.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
@Seeker47
Re imaging, I do know that the first time I used my backup app (R-Drive Image) to image a boot drive on a UEFI pc, I had to upgrade to the newer version of R-Drive. Same for the app's boot disk. But that was at at least eight or nine years ago. Have you tried posting for suggestions on the Macrium support forum? -
Not as yet, but I should pursue that. I think I did pose such a question to Acronis a couple years ago, but received no answer. Maybe persistence is required here.
For some of what I was alluding to in my previous thread post #54, I watched this YT video tonight
https://www.youtube.com/watch?v=t1eX_vvAlUc&pp=ygVHWW91ciBXaW5kb3dzIDExIENvbXB1dGVy4oC...TSBDaGlwcyA%3D
which indicates that the situation is even more dire and disturbing than I imagined. Some of the tech details exceed my understanding, but I think I get the gist of it. This further cements my decision re the hardware elements in question, and re any use of Win-11, ever since it debuted. I'm just not gonna play along with this crap, or become one of the vast herd of sheep.
[Incidentally, with the YT videos, I choose to avoid the annoying and often disgusting commercials that YT tacks on to the front of their videos, like this one. By downloading them instead with Tubedigger, or a couple other of the video downloaders I use, they chuck said commercials out the window, leaving you with just the video you were interested in seeing.]Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
How to get great audio quality for business video
By Bcreativeminded in forum AudioReplies: 12Last Post: 15th Oct 2022, 00:04 -
Anyone having the Lacie LaCinema Multimedia Device?
By seymoria in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2021, 16:00 -
business 8 channel video
By douggie in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2019, 20:03 -
Has anyone recently or ever done business with DigitalFAQ for capturing?
By CZbwoi in forum Capturing and VCRReplies: 22Last Post: 9th Oct 2017, 22:57 -
I am starting an audio repair business
By Haptic in forum AudioReplies: 2Last Post: 17th May 2017, 10:39
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
