After latest update I have issue with a mouse cursor. When I start playback the cursor is disapearing as intended but after a short while (1-2 seconds) it apears again and stays on screen whether its full screen or windowed. The setting in properties, to hide cursor, is ticked. The only way to solve this is to move mouse a little bit or fast forward or backward the playback with direction key.
I tried to disable PotPlayer in firewall but it also didn't work. Disabling auto update also won't help. But after some tests I noticed that this issue is related to white box ad in right corner, and happens every 10th time when I run the program. It's correlated with method to block this white logo box in right corner (edit hosts file method), if I remove all entries in hosts file, the cursor disappears but the white box is back.
Anyone have similar issue or is it just me?
After some heavy tests I'm 100% sure it's related to white box ad. I tried to add all of this entries to hosts file in different combinations also, because couple are reapeating, but with no luck. Sometimes it helps for a while, sometimes cursors stays on screen every time I start PotPlayer.
0.0.0.0 alea.adam.ad.daum.net
0.0.0.0 wat.ad.daum.net
0.0.0.0 display.ad.daum.net
0.0.0.0 analytics.ad.daum.net
0.0.0.0 ad.daum.net
::1 play.kakao.com
::1 track.tiara.daum.net
::1 t1.daumcdn.net
::1 p1-play.edge4k.com
::1 p2-play.edge4k.com
::1 p1-play.kgslb.com
::1 p2-play.kgslb.com
127.0.0.1 p1-play.edge4k.com
127.0.0.1 p2-play.edge4k.com
127.0.0.1 p1-play.kgslb.com
127.0.0.1 kyson.ad.daum.net
127.0.0.1 display.ad.daum.net
127.0.0.1 analytics.ad.daum.net
0.0.0.0 kyson.ad.daum.net
0.0.0.0 ad.daum.net
0.0.0.0 track.tiara.daum.net
0.0.0.0 p1-play.kgslb.com
0.0.0.0 p2-play.kgslb.com
0.0.0.0 t1.daumcdn.net
0.0.0.0 p1-play.edge4k.com
0.0.0.0 p2-play.edge4k.com
0.0.0.0 play.kakao.com
0.0.0.0 stat.tiara.kakao.com
14.34.8.217 adverweb.cjenm.com
219.249.227.136 videofarm.daum.net
211.249.201.89 display.ad.daum.net
211.249.222.41 play.kakao.com
121.53.104.194 analytics.ad.daum.net
121.53.105.173 p1-play.edge4k.com
121.53.105.173 p2-play.edge4k.com
211.249.221.178 potplayer.tv
121.53.105.173 potplayer.tv
211.249.221.178 potplayer.io
121.53.105.173 potplayer.io
121.53.105.173 potplayer.app
211.249.221.178 potplayer.app
I literally give up at this point. The only way is to leave it like that or delete all entries and let the box appear.
Results 1 to 1 of 1
PotPlayer playlist Issue
By sattu in forum Software PlayingReplies: 0Last Post: 14th Aug 2021, 07:39 -
Fixing PotPlayer no subtitles issue
By AlwaysAnonym in forum Software PlayingReplies: 0Last Post: 2nd Jan 2019, 18:23 -
PotPlayer: Advancing the Playlist issue
By lemings in forum Software PlayingReplies: 1Last Post: 22nd Jun 2017, 14:40 -
PotPlayer: how to hide mouse cursor during video playback?
By potuser in forum Software PlayingReplies: 2Last Post: 29th Apr 2017, 12:22
