Thread: Formating for older TV media players with handbrake
  1. #1
    Member
    Feb 2021
    Canada
    Posts
    22
    I know, been told many times here that the older tv should be scrapped or some other player should be added. I'm helping out an older financially challenged person that can't / won't do that. I'm stuck with an old tv.
    I've gathered up some files from friends of old movies. For this tv I reduce the video frequency but lately I've hit a problem that I can't see the answer to
    I'm finding that this TV will play standard width, height and aspect ratio files. For example 1280/720 16:9 will play fine. I think that 1920/1040 will work fine.
    1280/692 1.85:1 will not and 1280/546 2.35:1 will not play. Crashes the TV. What handbrake strategy / technique will get these files formatted for this thing?
    You guys have been so helpful, thanks. And I just love handbrake. What an amazing accomplishment.
    Member DB83's Avatar
    Jul 2007
    Posts
    10,081
    Re: Formating for older TV media players with handbrake
    Not sure if handbrake can do what I propose but avidemux can.
    The simplest thing is to force the video height to 720 pixels (1280 width) by adding borders top and bottom. So with your first example you require 14 pixels top and bottom and for the second example you require 87 pixels top and bottom
    Member
    Dec 2005
    Posts
    59,226
    Newer versions of Handbrake can add borders. You won't be able to add borders of odd sizes so instead of 87+87 you'll have to do 86+88.
    Jul 2007
    Posts
    10,081
    -delete-
    Jul 2007
    Posts
    10,081
    ^^ I guessed so much (although avidemux, theoretically, allows for odd numbers). I was merely relaying a basic theory.
    Member
    Dec 2005
    Posts
    59,226
    Quote Originally Posted by DB83 View Post
    Not for YUV 4:2:0 chroma subsampled video -- almost certainly what the OP will be working with. For non-chroma subsampled video both programs can add odd border sizes.
    I just didn't want the OP to be confused when he couldn't add 87+87 borders. And of course, the borders don't have to be (near) even. He could use for example, 64+110, any pairing that adds up to 174. Shifting the image up like that can be useful when using subtitles -- the subs can be rendered in the black border rather than over the active picture.
  1. Handbrake Color in Windows Media Player Classic (MPC-HC)
    By holgrave in forum Blu-ray Ripping
    Last Post: 20th Nov 2021, 15:58
  2. Replies: 15
    Last Post: 4th Dec 2019, 00:43
  3. Why do you think built in TV media players are so bad?
    By lingyi in forum Newbie / General discussions
    Last Post: 4th Aug 2019, 23:45
  4. Hardware Media Players that Will Display Closed Captions
    By cornemuse in forum Media Center PC / MediaCenters
    Last Post: 14th Apr 2019, 13:27
  5. Portable versions of media players
    By rowjekto in forum Newbie / General discussions
    Last Post: 26th Apr 2018, 12:13
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
