Hi,
can I record tiktok LIVE streams without screen recorder?
record native stream, on windows 10
thanx!
Results 1 to 13 of 13
Just find the .flv with developer tools -> network and use ffmpegCode:
ffmpeg.exe -i "https://pull-flv-f11-va01.tiktokcdn.com/stage/stream-2992808653961035849_or4.flv" tiktokkz.mp4
https://we.tl/t-BtyYR8HvyKCode:ffmpeg version 4.3.1-2021-01-01-full_build-www.gyan.dev Copyright (c) 2000-2021 the FFmpeg developers built with gcc 10.2.0 (Rev5, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100 Input #0, flv, from 'https://pull-flv-f11-va01.tiktokcdn.com/stage/stream-2992808653961035849_or4.flv': Metadata: publish_time_stamp: 1646653132 p_id : 5 ab : 0 link_info : n.de-uqzbsr.4pi9_1685625,n.us-fortto.lxdi_2396453,n.us-fortto.jwph_1941948 encoder : Lavf58.45.100 s_id : 8 h_id : 5 signResult : {"dynamicinfo":"5d59ce8926cef59ef7af2aea789c2a72","frametype":"1","lid":"2142840551","signinfo":"226658b1c9a112526650abef2f867a1cd48505b702b39b84d32feefa15b41aa31ce463523de63e017c301e5d18cc773c3400cbe0be68bbc4e1d41568b0e8b29fd0feaf88a7414e66586b7f6e7eb5d7 stream_id : push-rtmp-f5-va01.tiktokcdn.com:stage:stream-2992808653961035849_or4 server : TLSS/2.0.0(qcloud) server_version : 2.0.0 Duration: N/A, start: 175889.150000, bitrate: 1328 kb/s Stream #0:0: Video: h264 (High), yuv420p(progressive), 544x960, 1200 kb/s, 15 fps, 15.17 tbr, 1k tbn, 2k tbc Stream #0:1: Audio: aac (LC), 44100 Hz, stereo, fltp, 128 kb/s Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (aac (native) -> aac (native)) Press [q] to stop, [?] for help [libx264 @ 000002834248d8c0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 [libx264 @ 000002834248d8c0] profile High, level 3.1, 4:2:0, 8-bit [libx264 @ 000002834248d8c0] 264 - core 161 r3027 4121277 - H.264/MPEG-4 AVC codec - Copyleft 2003-2020 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=18 lookahead_threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=15 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00 Output #0, mp4, to 'tiktokkz.mp4': Metadata: publish_time_stamp: 1646653132 p_id : 5 ab : 0 link_info : n.de-uqzbsr.4pi9_1685625,n.us-fortto.lxdi_2396453,n.us-fortto.jwph_1941948 server_version : 2.0.0 s_id : 8 h_id : 5 signResult : {"dynamicinfo":"5d59ce8926cef59ef7af2aea789c2a72","frametype":"1","lid":"2142840551","signinfo":"226658b1c9a112526650abef2f867a1cd48505b702b39b84d32feefa15b41aa31ce463523de63e017c301e5d18cc773c3400cbe0be68bbc4e1d41568b0e8b29fd0feaf88a7414e66586b7f6e7eb5d7 stream_id : push-rtmp-f5-va01.tiktokcdn.com:stage:stream-2992808653961035849_or4 server : TLSS/2.0.0(qcloud) encoder : Lavf58.45.100 Stream #0:0: Video: h264 (libx264) (avc1 / 0x31637661), yuv420p, 544x960, q=-1--1, 15.17 fps, 11648 tbn, 15.17 tbc Metadata: encoder : Lavc58.91.100 libx264 Side data: cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: N/A Stream #0:1: Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 128 kb/s Metadata: encoder : Lavc58.91.100 aac frame= 1947 fps= 16 q=-1.0 Lsize= 9625kB time=00:02:09.11 bitrate= 610.7kbits/s dup=11 drop=0 speed=1.09x video:7499kB audio:2057kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.713952% [libx264 @ 000002834248d8c0] frame I:8 Avg QP:14.22 size: 26023 [libx264 @ 000002834248d8c0] frame P:550 Avg QP:17.14 size: 9128 [libx264 @ 000002834248d8c0] frame B:1389 Avg QP:20.61 size: 1764 [libx264 @ 000002834248d8c0] consecutive B-frames: 3.1% 3.7% 4.6% 88.5% [libx264 @ 000002834248d8c0] mb I I16..4: 39.2% 46.2% 14.7% [libx264 @ 000002834248d8c0] mb P I16..4: 2.0% 6.8% 1.0% P16..4: 20.1% 12.4% 6.3% 0.0% 0.0% skip:51.3% [libx264 @ 000002834248d8c0] mb B I16..4: 0.2% 0.5% 0.0% B16..8: 23.7% 3.9% 0.7% direct: 0.7% skip:70.2% L0:45.7% L1:46.7% BI: 7.7% [libx264 @ 000002834248d8c0] 8x8 transform intra:66.3% inter:69.3% [libx264 @ 000002834248d8c0] coded y,uvDC,uvAC intra: 47.1% 54.5% 17.7% inter: 7.8% 7.3% 0.1% [libx264 @ 000002834248d8c0] i16 v,h,dc,p: 42% 28% 9% 21% [libx264 @ 000002834248d8c0] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 18% 22% 3% 5% 7% 5% 6% 4% [libx264 @ 000002834248d8c0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 32% 17% 17% 5% 7% 8% 5% 6% 3% [libx264 @ 000002834248d8c0] i8c dc,h,v,p: 55% 18% 22% 6% [libx264 @ 000002834248d8c0] Weighted P-Frames: Y:0.4% UV:0.0% [libx264 @ 000002834248d8c0] ref P L0: 66.9% 13.6% 15.1% 4.4% 0.0% [libx264 @ 000002834248d8c0] ref B L0: 91.9% 6.8% 1.3% [libx264 @ 000002834248d8c0] ref B L1: 96.9% 3.1% [libx264 @ 000002834248d8c0] kb/s:478.51 [aac @ 0000028342378000] Qavg: 3620.546 Exiting normally, received signal 2. -
ok thanx.
is there any other system or method to register directly from the tiktok official link
and not from the .flv link?
the problem is that the .flv link changes every time the titktoker connects with another person
or when there is a small interruption of the flow and therefore the problem is that the recording stops.
thank you -
Yes, you can record TikTok live streams without using a screen recorder on Windows 10. One way to do this is by using third-party software such as O BS Studio or Ban dicam. These software allow you to capture the video and audio output of your computer and save it as a separate file. All of that I know because I use TikTok for already 4 years and have gained a lot of experience already. I can share with you a service that will help you become popular on TikTok in a matter of time. I am talking about SocCeleb, the website where you can order followers, likes, and views.
No, currently there is no built-in feature within TikTok that allows you to record live streams without using a screen recorder. However, there are various third-party screen recording apps available that you can download on your device to record the live stream. Please note that it is important to obtain permission from the person hosting the live stream before recording, as it is a violation of their privacy to record them without their consent. Additionally, it is important to respect TikTok's community guidelines and terms of service when recording content on their platform. You can buy likes at https://iamat.com/buy-tiktok-auto-likes/.
It had been downloading this way for several days, but now when it downloads, it says:
[flv @ 0000016f630ae3c0] Video codec (c) is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
I already updated ffmpeg, tried to see if it works in VLC, install more codecs, and it didn't work either. I think something has done Tiktok. Do you know if the video is encrypted?
With Yt dlp is downloaded, but the file doesn't play. :/ -
AnonymousGuest
When getting the FLV link for the Tiktok livestream. Usually it downloads from the segment or time you enter. So if a user started for example 10 minutes prior and you just entered you missed the first 10 minutes so the live downloads incompletely. How to download it completely even if you enter the livestream late?
mpd protected live streams
By Moneyshot in forum Video Streaming DownloadingReplies: 0Last Post: 11th Feb 2022, 09:31 -
Download Live Streams
By sowie in forum Video Streaming DownloadingReplies: 13Last Post: 6th Aug 2021, 16:18 -
PotPlayer open dailymotion live streams ?
By dxellas in forum Software PlayingReplies: 12Last Post: 19th Dec 2020, 20:22 -
Need help with downloading live streams from new player on camsite
By BiankaHolms in forum Video Streaming DownloadingReplies: 0Last Post: 19th Jul 2018, 10:14 -
Youtube Live Streams Help
By ghostrewel in forum Video Streaming DownloadingReplies: 1Last Post: 21st Jan 2018, 12:42
