Greetings,
I fly a Mavic Mini 2 which has digital zoom capabilities. Sometimes I find it a bit difficult to get a smooth zoom effect while flying, so I'm thinking maybe it's best to leave it until postproduction. If I have it correct, both scenarios are digital, so the quality of the image should not be superior in one over the other. Of course there are probably advantages to each scenario, but in general which would you choose and why?
Thanks,
Ken
Real zoom is better than processed zoom. IMHO
Tried it with my own drone and postprocessed isn't as good.It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
Think in terms of scaling and (over-) sampling. If you had a 1080p image and wanted to do a seamless 2x zoom in, you cannot do it starting from a 1080p image, because the end result of the zoomed section would be crude, with lower effective resolution. What you need to do is start with a 4k image resampled to 1080p, and then a zoom in to a REAL 1080p window inside the 4k image will be seamless.
As you can guess, the factor of the (high quality, seamless) zoom is determined by the oversampling factor. So for a smooth 8x zoom in, you would need to be starting from an 8x oversampled image.
That is why optical zoom is regularly preferred over digital zoom - because the optical zoom, being analog, is THEORETICALLY capable of infinite oversampling. Though in reality it is limited by the constraints of the optics (zoom ratio, light level, artifacts).
Set zoom, double click to edit, change, go back to Scene 0, zoom is changed
By d0ugparker in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2022, 15:28 -
How to give an mp4 a zoom out effect while the animation plays?
By Mugunga in forum EditingReplies: 4Last Post: 30th Oct 2021, 22:02 -
Shooting a film
By David Banner in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 25th Aug 2020, 17:00 -
How to burn subtitles without shooting myself?
By dimailer in forum SubtitleReplies: 7Last Post: 3rd May 2020, 14:26 -
Zoom in effect of video in the background, in a video slightly in advance a
By HiLem in forum EditingReplies: 1Last Post: 30th Jul 2018, 20:20
