  1. Hello,
    I have got a videofile stemming from a Korean DVD (should be NTSC).
    It is a badly deinterlaced(I guess?) version of that DVD and it shows very severe frame blending.
    The video seems to be encoded in progressive, it is originally a h265 file.
    I uploaded a sample of the butchered video ("bad.mkv")
    I have not really been able to make out a pattern, but I'm pretty sure it is:
    Three full frames -> ~Three blended frames -> Three full frames -> etc. etc.
    The blending does not seem to be constant, because it looks like some frames are "more evenly blended" than others and some look like they exhibit a small amount of ghosting.
    I feel like the original was incorrectly deinterlaced, as these NTSC dvds should really be detelecined, no?
    The original footage is shot on film and was originally released in PAL Regions on a 50i DVD. I have uploaded a sample of that as a reference for how "it is supposed to look" ("good.mkv")
    I have no idea how to handle this weird pattern of full frame and blending.
    Can someone help me rescuing this butchered file? Are they even rescuable?
    Thank a lot for your help
    Aug 2004
    PA USA
    I see the problem in your bad.mkv, def have 3 > 3blended > 3 going on. Have a look at this link.
    http://avisynth.nl/index.php/Removing_blended_film_frames_on_vcds
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
  3. If you have a good version why do you care about the bad version?
    <edit>
    I see. I downloaded the "good" video and although there's no blending it has lots of levels, colors, and noise problems.
    I don't think you're going to be able to remove the blending in the bad video. And next time, some shots with a little more motion would be better. Especially a panning shot.
    </edit>
  4. Originally Posted by sum_guy View Post
    Thank you, that looks promising :)
    Sadly the "good" version has much poorer image quality than the "bad" version. (well except the blending that is)
  5. Originally Posted by limocello View Post
    That's for a very specific kind of blending. It won't work with your source.
  6. I don't really see a pattern when looking at the frames:
    0 ok
    1 ok
    2 blended
    3 blended
    4 blended
    5 blended
    6 ok
    7 ok
    8 ok
    9 ok
    10 blended
    11 blended
    12 ok
    13 ok
    14 ok
    15 ok
    16 blended
    17 blended
    18 ok
    19 ok
    20 ok
    21 ok
    22 blended
    23 blended
    24 ok
    25 ok (scene change)
    26 ok
    27 blended
    28 blended
    29 blended
    30 ok
    31 ok
    32 ok
    33 blended
    34 blended
    35 blended
    36 ok
    37 combing
    38 ok
    39-64 ok (identical)
    65 combing
    66 blended
    67 blended
    68 ok
    69 combing
    70 blended
    71 blended
    72 ok
    73 ok
    74 ok
    75 blended
    76 blended
    77 combing
    78 ok
    79-84 ok (identical)
    85 combing
    86 ok
    87 blended
    88 ok
    89 blended
    90 blended
    91 ok
    92 ok
    93 blended
    94 blended
    95 blended
    96 blended
    97 ok
    98 ok
    99 ok
    100 blended
    (some more might be blended but got overlooked since I didn't spot the blending)
    -> I doubt anything that assumes a fixed pattern will fail.
    I also doubt one can retrieve the orginal frame from those 3-4 blended frames in a row automatically. (don't think there is any ml based approach to remove blending, is there?)
