I resurrected and old PC, Windows 11, and even go Firewire working. I can capture my Canon MiniDV using SClive but everything is broken into scenes. I want to burn the tapes to a DVD. Can I just add all the scenes, or should I recapture and change the settings so it just captures each tape in it's entirety.
1) Is there a difference if I capture whole tape or let it break it into scenes.
2) If I do want to capture a whole tape without individual splits, where are the setting in SCLive to do this? Which setting.
Thanks.
There are several settings.
So you need to go through the list. For example, the default filesize is 2 gb in size whereas you will probably need to reset that to unlimited.
If you want specific scenes to be detected then look at 'Scene Detection Mode'
This is a matter of personal preference. It is quite logical to have unique scenes as individual items in a dvd which you can then author as a menu for selection. -
File>Options.
Each group of settings is under a tab. Or you can look at the "All Settings" tab.
I like splitting the scenes because when I'm editing the footage, the scene-breaks are already there. Also, the exact date and time for each scene are put in the filename.
You can adjust the time gap before Scenealyzer will split the scenes eg set it to 12 hours and you'll get all the video from each day in one file.
Capturing miniDV tapes. Very new to this. Please Help.
By JontheScott in forum Capturing and VCRReplies: 38Last Post: 12th Jun 2021, 05:20 -
Capturing Digital onto MiniDV
By lordomega in forum Capturing and VCRReplies: 6Last Post: 3rd Jan 2021, 18:31 -
Sclive Writes 48Khz Files No Matter What
By dellsam34 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 20th Dec 2020, 10:35 -
A (Most Likely) Dumb Question About Re-encoding Lossy Formats
By enter8 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2019, 19:11 -
Canopus ADVC 100 Firewire DUMB question
By Tolwyn in forum Video ConversionReplies: 7Last Post: 7th May 2017, 00:17
