Results 1 to 27 of 27
  1. A freinds asked me to make a VCD of Spiderman. I dl the moive eveything going great so I check the movie to see if it is ok and all I see is a blank screen. No Errors pops but no sound or picture. I have divx and my other divx films work great.
  2. its probably not a movie file .
    Are you converting from divx to vcd, and if so is it the mpg file that gives u no pic or sound? Sounds like its the divx though.
    What's the file size?>
    ztr
  3. Originally Posted by El_Mero_Zooter
    its probably not a movie file :).
    ztr
    It is the orgianl file. the AVI file. Strange All my other DIVX moive work fine.
  4. are you saying that when you try to play it, it shows a blank screen, or when your converting it has a blank screen?
    also what program are you using to convert to vcd and what program for playing it?
  5. Originally Posted by Murrdawg045
    When I try and play is a blank screen no sound no error. I have yet to convert it the AVI comes up blank. I have DivX and my other Divx flims work fine.
  6. Sheesh!
    why bother with it? ....I know a sweet FTP that can solve your problem!
    Capish! :)
    "If hustling is deviance in the eyes of the lord, then in my realm he is blind"...B*Tip - Back in the day!
    May 2002
    Belfast, Northern Ireland
    Originally Posted by BTIP
    Sheesh!
    Capish!
    Would you care to share the FTP address? Or alternatively e-mail me on paul.leahey@btinternet.com
    Capish!
  8. Originally Posted by Verbatim
    It looks like there is a ton of fake spiderman films it has even hit the news groups. never seen it this bad for one flim. OH! Well
    May 2002
    I just downloaded the SVCD Centropy version from the newsgroups - fantastic quality and a trailer for Ang Lee's Hulk too!!
  10. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Don't be ripping off my movie ............LOL.....
    The Centropy Telesynch version is an SVCD. Is your player capable of playing SVCD's ? Did you burn out the bin/cue with CDRwin ? Or extract the DAT"s and try to re-author it ?
    The film is available on a few FTP's as well as off of edonkey's http://sharereactor.com forum
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  11. The centropy version I downloaded says it is svcd but shows in Nero as an avi. I am running it through tmpgenc to make sure it is svcd, but the file is going to be like 2.3 gb. How can I split it into disc sized parts?
  12. Spidey: do you have to be running edonkey to use share reactor? I clicked on download but nothing appears to have happened.
  13. What are some of the FTP's? or newsgroup sites ? where i can download from
  14. Downloading Spider-Man (or any other film, for that matter) is illegal. Perhaps this isn't the place to discuss it. Try the boards at <www.isonews.com>.
  15. Originally Posted by todd_24089
    same here ZIP 0 nothing
  16. I found their FAQ. You have to be using edonkey.
  17. Is sharereactor/Edonkey safe? Does it log ip's or anything? Has anyone ever been busted for downloading from there?
  18. lol...there is no reason to be scared to download pirated anything these days from the web, especially from sharing programs..
  19. I know. I just didn't want to take any risks.
  20. Originally Posted by VincentVegaFFF
    as far I know as long just swap dat type files you be fine. only stay away from .exe and .com files
  21. The same happened to me, I tried playing it in all of my movie players and none worked, oh and BTIP, could you PM me with the info on that FTP? thanx
  22. Which group did you get the Centropy version from?
    Dai
  23. it was up on a.b.vcd i think
  24. Ok Guys and Gals... About the Spiderman By Centrophy.. I have a issue that one of you might be able to help me out with. I have this version of Spiderman right now and I went to Damonize it (instead of burning it) to get the two mpg files. (Intro and First CD Movie File) All I want to do is Make a regular mpg or avi out of it.. does anyone have any ideas?
    This is in reference to http://forum.vcdhelp.com/viewtopic.php?t=93098
    If you have the time please look at it. Thanks
    Armega
  25. Hello there!!!
    What U need to do is use dvd2avi to extract the audio from the video & then place your finished files into tmpeg & re-encode it back to vcd its a simple as that!! disk1 & 2 will need to be merged in mpeg tools after encoding! they fit 2gether perfectly without any gap & well your disk 3 will be a 38min vcd which is now the new disk 2.
    what U need....
    ISObuster to extract the file to an mpeg to the drive ie spider1.mpg
    dvd2avi to seperate the audio from the video..
    here are the settings!!!
    1.select track 1 in the audio
    2.channel format is mpegaudio
    3.leave dolby digital as decode
    4.mpegaudio is set to decode
    5.48>44khz leave off
    finally save your project...
    next step choose your template in tmpeg!! has to be vcdmpg1 pal at 352*288... U know what I mean
    open your video file which is a *.d2v file
    open your audio file which will have the extension mpa. to open this U need to look for all files as it wont look properly for the mpa file.
    once all this is done U can encode your vcd... there U go! merge your first 2 completed mpegs 2gether in the tools section then burn the finished file to an 80 min cd, the same process applies to disk 3 of the supervcd.
    I hope this was what U needed!!!
    Kev!
  26. hehe thanks again painkiller..
    Armega
  27. Hello everyone i have the DVD version is a good quality widescreen and full screen 5.1 dolby and 2.0 dolby subtitles features chapters good dvd and all the menus are English not chinesse.
    Exelent movie.
