Results 301 to 330 of 611
Now I'm getting "No module named Cryptodome", and "pip install Cryptodome" throws "No matching distribution found".
Okay, now when I plug in the PSSH and licence I've found, I get "AttributeError: module 'headers' has no attribute 'headers'.
Don't feed the seagulls!
OK You're a bright man - what do you think it might mean?
'Module headers' suggest an import , headers.py perhaps?
no attribute? Well that sort of suggests there is nothing called header in headers.py - don't you think?
This game is all about paying attention to detail and thinking what the error messages actually mean. That saves you making like a child at every error you meet and wanting your hand held. -
Ah, so it relates to this bit:
I don't know what a request header is, what a cURL is, or how to edit a .py file. Doesn't really matter how bright I am or am not, I just have zero experience with most of what's in use here.I found an encrypted video to download, located the request headers saved as a cURL and encoded intp python here:- https://curlconverter.com/ . I put them in headers.py in the WKS-KEYS folder. -
Then what are you doing here? Anyone who has been through school, since about 1985, should know about computers and editing files at the very least. There has to be a minimum knowledge base before people can jump in here and expect to get everything straight away.
So :-- So google 'how to edit a python file'
- Google 'what is a cURL'
- Look at curlconverter.com
- Read the next chapter: https://forum.videohelp.com/threads/407216-Decryption-The-Dungeon-of-Despair
If you really are inept at using a computer as you suggest, perhaps you should come back later when you are ready. It is unfair on everyone here to be expected to baby step tyros. -
There's a "copy as cURL" option on the mpd, but not in the headers section that appears when you click on it. Is that the one I want? I'd have expected something header-specific, given your description.
I tried it, but it then throws the error "ciphertext with incorrect length", so I would guess not. -
The mpd gets you a video that is encrypted.
The licence url (in the browser) is showing where the browser goes to look for keys. It is the LICENCE URL which you consult for headers. Because you want to go there to to get your keys with your CDM. Clearly you haven't understood process yet. Not surprising as there is a lot to take on. So re-read Temple of Doom from sub heading Decryption. And don't cheat! Read it carefully it is information dense. Dungeon of Despair details headers quite a bit so add that to your reading.
I'm still baby-stepping you over information already given in the two places mentioned. I wrote those because at the time I'd spent weeks trying understand what CDM stood for. It is an exposition of all you need, presented in one place, for you to go from tyro to medium-proficient at key getting. I find the fact that people can't/won't study it, and insist on asking questions already answered, mystifying. -
I'm not even sure it does that, TBH, because I tried downloading it figuring at least if I have it down I can sort keys out in less of a rush, but it was only a few megabytes for a two-hour video which is clearly wrong (note: I'm not using any of your sample sites for this). But that's a whole different bridge to cross.
Okay, so I went to the licence URL in my browser. Copied the licence document as a cURL. Pasted the cURL into cURL converter, copied everything between the curly brackets plus the "header =" that precedes the opening bracket, pasted that into headers.py in Notepad, ran l3.py, pasted in a PSSH (there are dozens of PSSHs, I'm not sure if it matters which I pick) and the licence URL, and...still got the "ciphertext with incorrect length" error.It is the LICENCE URL which you consult for headers. Because you want to go there to to get your keys with your CDM. -
Two things:
for the mpd, one way to see what video and audio is available is
Code:yt-dlp --allow-u -F < your mpd url >
You said when referring to PSSH."I'm not sure if it matters which I pick)"
It does. You need to look at a few things more carefully. If there are lots of PSSH strings why would it be ok to pick just any?
I cannot fathom why you are stuck at the end of this thread just casting about and hoping it will work.
You've seriously missed something out at the very start. Have you ever got keys for any site?
Forget about downloading your present target; it is clearly beyond your experience yet.
Go back to post #1. Start at the heading Decryption and DO ALL THE EXAMPLES yourself. That experience is important.
Once you've got keys for a couple of simple sites you'll know which is the correct PSSH just by looking at it. (All widevine PSSH starts with 'AAAA' and they are far shorter in length than other PSSH. Read the XML of an mpd - Google 'XML formatter' and look at it formatted. Look to see where all the PSSH are nested and look at your chosen one. Spot any differences.
Be observant. Keep your brain in gear. Pay attention to detail. In this game 9 out of 10 will not do. Everything needs to be exactly right. -
The only thing I missed was that PSSH starts with 'AAAA', I misread it initially as just 'AAA'. But it's confirmation I have the right PSSH, there's two as far as I can tell (there are many, many PSSH tags but they appear to just repeat the same two values over and over) and only one starts with 'AAAA', the other starts with just 'AAA'. The one with 'AAAA' is also much shorter, which jives with what you're saying above.
So it would appear I have the right PSSH from the MPD file. I still have no idea what the ciphertext error refers to. -
The correct PSSH is the one in this bracket:
EDEF8BA979D64ACEA3C827DCD51D21ED is the system ID for Google Widevine, so if you see a PSSH in the tags holding this system ID, you can be positive that this is the one you are after.Code:<ContentProtection schemeIdUri="urn:uuid:EDEF8BA9-79D6-4ACE-A3C8-27DCD51D21ED"> <cenc:pssh>AAAA...=</cenc:pssh> </ContentProtection>
But reading it isn't enough. Clearly you haven't got any keys yet. I asked you twice.
The only way to prove your system works is to try with bitmovin and/or tg4.ie. You need to follow instructions.
You appear to be cutting corners, trying for a pay site, you cannot mention, with your first attempt.
You claim missing AAAA was your only error. You supposedly understand logical tautology but fail to see the lack of logic in that comment. How can you possibly know if you've missed something else?
You can caste about for as long as you wish. But do it on your own would you and not in this thread - since it hasn't been of any use to you.
The faster, proven way is to take it step by step and understand the process. But apparently that's not you.
Finally, thanks for offering honorifics but 'dude' and 'prick' don't really apply to women do they?.
All the information is in post 1. Most users have had easy success. What is different about you?
I'm out. I think you are a time waster.
widevine decryption help
By birbal1 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2021, 11:11 -
Help with video download and decryption
By herschel in forum Video Streaming DownloadingReplies: 4Last Post: 26th Jul 2021, 05:31 -
How do I get the decryption key
By Bakekalu in forum Video Streaming DownloadingReplies: 6Last Post: 5th Jul 2021, 02:25 -
Cloudfront video download, decryption?
By Md_95 in forum Newbie / General discussionsReplies: 7Last Post: 5th Apr 2020, 08:53 -
Question about decryption of .m2ts files
By mwalimu in forum Blu-ray RippingReplies: 8Last Post: 23rd Jun 2019, 15:47
