I would like run my video through VirtualDub to analyze it after I had done some work on it in Selur Hybrid in order to see some numbers associated with my changes [using the #Histogram("Levels") and ColorYUV(Analyze=true) analysis].
Which Processing Video codec should I pick in Selur Hybrid? I've tried a few including FFVH and the AVS/VirtualDub script gives me various Avisynth open failure errors, such as:
- Histogram: Levels mode only available in PLANAR
- ColorYUV: Only work with YUV colorspace
How should I go about solving this? Adding the regular HuffYUV to Hybrid (is that even possible)? Adding something to the VirtualDub2 subfolders to make it access the codec(s) using in Hybrid?
Example of my AVS script.
DirectshowSource("test.avi")
INFO ON MY AVI FILE
Format : AVI
Format profile : OpenDML
File size : 4.22 GiB
Duration : 24 s 892 ms
Overall bit rate : 1 455 Mb/s
Writing application : MEncoder SVN-r38327-11.2.0
Writing library : MPlayer
Video
Format : HuffYUV
Format version : Version 3
Codec ID : FFVH
Bit rate : 1 452 Mb/s
Width : 2 560 pixels
Height : 1 440 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:4:4
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 6.570
Stream size : 4.21 GiB (100%)
Basically, don't use DirectShowSource(). But since you are, try adding ConvertToYV12() or ConvertToYV12(interlaced=true) right after it.
Histogram for Amarec TV
By Alwyn in forum Capturing and VCRReplies: 15Last Post: 3rd May 2023, 08:05 -
avi files crashes or stalls in Hybrid
By Rahneshin in forum Video ConversionReplies: 12Last Post: 21st May 2021, 08:30 -
Interpreting VirtualDub Capture Histogram
By anachronon in forum Capturing and VCRReplies: 63Last Post: 10th May 2021, 10:10 -
play video with histogram display, avisynth+ ?
By butterw in forum Newbie / General discussionsReplies: 44Last Post: 14th Oct 2020, 04:22 -
Out-of-bounds memory error exporting virtualdub
By vidphil in forum Video ConversionReplies: 23Last Post: 10th Jul 2018, 18:55
