I'm sure this has been asked, but I'm probably Googling it wrong since I can't find a solution.
I'm trying to inverse telecine from a blu-ray source.
My go to script for DVDs is:
Since the source is AVC I'm using DGIndexNV instead of regular DGIndex, but that outputs a .dgi file which seems to be incompatible with "d2v=" in TIVTC.Code:mpeg2source("Source.d2v") loadcplugin("yadif.dll") TFM(pp=2,clip2=yadif(mode=0),d2v="Source.d2v") tdecimate()
I'm open to suggestions on to how to make this work or a better alternative.
If MPEG2Source opens it, then why are you using DGIndexNV at all? Can't you use DGIndex?
I don't know what source filter you're using. Leave out the ",d2v="Source.d2v" as you don't need it. And Yadif would probably be the last filter I'd use to post-process it. Even the default is of better quality.
TFM(pp=2")
tdecimate()
Or use LSMASHVideoSource or LWlibavVideoSource. -
As you you seem to have NVidia graphics you can also try
Code:DGSource("your.dgi") DGTelecide().DGDecimate()
https://forum.videohelp.com/threads/404932-Handling-moire#post2649769 -
For AVC you can can also use ffVideoSource() or LSMASHVideoSource() or LWlibavVideoSource().
Chroma Ghosting on AviSynth IVTC
By BruceKaneWayne in forum Video ConversionReplies: 3Last Post: 24th May 2020, 15:26 -
Avisynth manual IVTC trouble
By LoopinFool in forum RestorationReplies: 27Last Post: 16th Apr 2020, 13:42 -
QTGMC/IVTC issues on AVISynth/AvspMod
By Fraugster in forum RestorationReplies: 33Last Post: 7th Aug 2019, 07:55 -
2 questions about IVTC in Avisynth
By Megafox in forum Newbie / General discussionsReplies: 13Last Post: 22nd Feb 2018, 21:56 -
By Megafox in forum Newbie / General discussionsReplies: 0Last Post: 21st Feb 2018, 16:24
