Lets say i have a bluray disk,
1. i made a mkv file without any encode from the bluray disk
2. i encode the mkv file reasonably good bitrate, lets say 10~14mb/sec, x264 codec/format.
now i want to encode the file to x265 codec. reasonably lower bitrate. lets say 4mb/sec. will it be fine if i encode the x265 file from the encoded file (option 2) or i will lose a
significant data. basically my question is which source file will give better output or there will be no difference or very small difference.
sorry for my bad english.
For best quality, go back to non-encoded MKV file and use that as the source for your new
x265 encode -
It depends on what your definition of "significant" is. You should just try both and decide for yourself.
In case it wasn't clear... Each encoding with a lossy codec loses quality. So a two step encode from a source to x264 then to x265 will lose more quality than a single encode from a source to x265. Given the relatively high bitrate of your x264 intermediate, and the much lower bitrate of your x265 encoding, the difference probably won't be very big. But whether that's "significant" is up to you.
big color gradient 8bit vs 10bit X265 encode from 8bit source PLZ help
By kamyar in forum Newbie / General discussionsReplies: 0Last Post: 21st Apr 2021, 04:51 -
QTGMC and VFR question about mixed framerate from source
By LaserBones in forum Newbie / General discussionsReplies: 14Last Post: 9th Jul 2020, 07:04 -
Encode DVD source and retain original video dimensions
By ss2012 in forum Newbie / General discussionsReplies: 34Last Post: 22nd Jan 2020, 12:33 -
Is it good to encode videos with higher bitrates than the source?
By onlinegft22 in forum Video ConversionReplies: 2Last Post: 20th Jun 2018, 12:33 -
can QSVencc encode multiple .avs as source?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2017, 10:31
