  1. Using Selur Hybrid, I want to apply a very light stabilization of a home movie using Stabilizer (in Filtering-Vapoursynth-Frame-Stabilize) with Shift Max 4/4. How do I then cover up those shifting edges/moving black bars? I've tried different setting in the Crop/Resize tab, but I can't figure out how cover up the stabilization. What do I need to adjust in these settings (see attached)?
Name:	Hybrid - Stabilizer and Cropping settings.PNG
  2. https://forum.selur.net/thread-1200.html
    I think Hybrid uses Depanstabilize. If you use that directly, the key thing is to set mirror=15.
  3. Yes, Hybrid uses Stab (from https://github.com/Selur/VapoursynthScriptsInHybrid/blob/master/lostfunc.py).
    Adjusting the filter order (move 'Stab' above 'Crop') under "Filtering->VapoursynthMisc->Filter Order/Queue" will probably help.
