Hello guys,
I have been trying to run Hdr Agc 1.8.7-https://forum.doom9.org/showthread.php?t=93571
This dll is 32bit dll. It is so inconvenience for running 32bit in 64bit windows.
MP_pipeline sometimes does not work properly.
One of the main attractions of HDRAGC is it's ease of use
More difficult to use - but smoothadjust with smoothcurve, smoothcustom expressions can get similar results. If you want even more control, you can use resolve and export a .cube lut . Avscube can read .cube luts . There are also curve plugins such as gradation (a gradation curves port) -
Thanks poisondeathray.
Moreover,
Do doom9 and videohelp teach about color correction? Do you know any Thread about this? -
There are many posts and examples about color correction, but it might be difficult to find what you exactly want (not organized in a single comprehensive thread) . And many topics/discussions are duplicated
Definitely you need to look at video scopes like histogram in avisynth (a waveform monitor)
Sometimes it helps if you post a sample clip and ask for suggestions, people will provide suggestions - it's a good way to start learning
Often there are multiple ways to get similar results
Some people find GUI based programs easier to use, such as NLE's, davinci resolve. They have other benefits such as keyframing, easier to use masking/rotoscoping, curves, better realtime feedback
Help with running MP_Pipeline and AGC. PLEASE check my script.
By JeremyVN in forum Video ConversionReplies: 10Last Post: 1st Mar 2022, 15:29 -
fftw 3.3.7 DLLs
By Marsia Mariner in forum ComputerReplies: 2Last Post: 15th Oct 2021, 15:41 -
Create a drop shadow as well as a transparent drop shadow?
By Bass_Soul in forum SubtitleReplies: 0Last Post: 26th Nov 2020, 01:28 -
Aegisub: shadow blur
By Hakunamatata67 in forum SubtitleReplies: 0Last Post: 15th Aug 2020, 16:12 -
VHS playback video AGC? Bright flashes = waveform monitor loses sync
By Brad in forum Capturing and VCRReplies: 8Last Post: 9th Apr 2020, 22:35
