Results 1 to 10 of 10
  1. Hello, I have been trying to attach/apply my custom SDR LUT to my HDR clip to control the SDR Conversion on YouTube.
    I have read a lot of tutorials and watched videos on YouTube how to do this, but I still fail to do it.
    I am not sure on what or where the mistake is, if I am doing something wrong or if the issue is connected to something else.
    I am on Windows 10.
    Here is what I did step by step:
    1. Recorded my playthrough in HDR using Elgato 4K60 S+
    2. Edited and rendered a simple short clip to test this method to attach/apply custom SDR LUT
    3. Opened my rendered video in Davinci Resolve again and made a SDR LUT(cube file) after some grading.
    4. Downloaded mkvmerger from given link (github) on Google Support
    5. Extracted the Windows x64 version to my User accounts folder. C:/Users/Saiyan
    6. I placed my LUT file (HDR_To_SDR_LUT) in the same folder as mkvmerge.exe
    7. Placed my video file as well (HDR_To_SDR_LUT.mp4) in the same folder with the two other above.
    8. Ran CMD, "C:\Users\Saiyan>" is the typical first line which opens up. I pasted my command
    C:\Users\Saiyan\hdr_metadata-master\hdr_metadata-master\windows\64bits\mkvmerge.exe
    -o HDR_To_SDR_LUT.mkv \
          --colour-matrix 0:9 \
          --colour-range 0:1 \
          --colour-transfer-characteristics 0:16 \
          --colour-primaries 0:9 \
          --max-content-light 0:1000 \
          --max-frame-light 0:300 \
          --max-luminance 0:1000 \
          --min-luminance 0:0.01 \
          --chromaticity-coordinates 0:0.68,0.32,0.265,0.690,0.15,0.06 \
          --white-colour-coordinates 0:0.3127,0.3290 \
          --attachment-mime-type application/x-cube \
          --attach-file HDR_To_SDR_LUT.cube \
          HDR_To_SDR_LUT.mp4
    This is what came up:
    C:\Users\Saiyan>C:\Users\Saiyan\hdr_metadata-master\hdr_metadata-master\windows\64bits\mkvmerge.exe
    mkvmerge v9.3.1 ('Mask Machine') 64bit
    Error: no output file name was given.
    mkvmerge -o out [global options] [options1] <file1> [@optionsfile ...]
     Global options:
      -v, --verbose            Increase verbosity.
      -q, --quiet              Suppress status output.
      -o, --output out         Write to the file 'out'.
      -w, --webm               Create WebM compliant file.
      --title <title>          Title for this output file.
      --global-tags <file>     Read global tags from an XML file.
     Chapter handling:
      --chapters <file>        Read chapter information from the file.
      --chapter-language <lng> Set the 'language' element in chapter entries.
      --chapter-charset <cset> Charset for a simple chapter file.
      --cue-chapter-name-format <format>
                               Pattern for the conversion from CUE sheet
                               entries to chapter names.
      --default-language <lng> Use this language for all tracks unless
                               overridden with the --language option.
      --generate-chapters <mode>
                               Automatically generate chapters according to
                               the mode ('when-appending' or 'interval:<duration>').
      --generate-chapters-name-template <template>
                               Template for newly generated chapter names
                               (default: 'Chapter <NUM:2>').
     Segment info handling:
      --segmentinfo <file>     Read segment information from the file.
      --segment-uid <SID1,[SID2...]>
                               Set the segment UIDs to SID1, SID2 etc.
     General output control (advanced global options):
      --track-order <FileID1:TID1,FileID2:TID2,FileID3:TID3,...>
                               A comma separated list of both file IDs
                               and track IDs that controls the order of the
                               tracks in the output file.
      --cluster-length <n[ms]> Put at most n data blocks into each cluster.
                               If the number is postfixed with 'ms' then
                               put at most n milliseconds of data into each
                               cluster.
      --no-cues                Do not write the cue data (the index).
      --clusters-in-meta-seek  Write meta seek data for clusters.
      --disable-lacing         Do not use lacing.
      --enable-durations       Enable block durations for all blocks.
      --timecode-scale <n>     Force the timecode scale factor to n.
      --disable-track-statistics-tags
                               Do not write tags with track statistics.
     File splitting, linking, appending and concatenating (more global options):
      --split <d[K,M,G]|HH:MM:SS|s>
                               Create a new file after d bytes (KB, MB, GB)
                               or after a specific time.
      --split timecodes:A[,B...]
                               Create a new file after each timecode A, B
                               etc.
      --split parts:start1-end1[,[+]start2-end2,...]
                               Keep ranges of timecodes start-end, either in
                               separate files or append to previous range's file
                               if prefixed with '+'.
      --split parts-frames:start1-end1[,[+]start2-end2,...]
                               Same as 'parts:', but 'startN'/'endN' are frame/
                               field numbers instead of timecodes.
      --split frames:A[,B...]
                               Create a new file after each frame/field A, B
                               etc.
      --split chapters:all|A[,B...]
                               Create a new file before each chapter (with 'all')
                               or before chapter numbers A, B etc.
      --split-max-files <n>    Create at most n files.
      --link                   Link splitted files.
      --link-to-previous <SID> Link the first file to the given SID.
      --link-to-next <SID>     Link the last file to the given SID.
      --append-to <SFID1:STID1:DFID1:DTID1,SFID2:STID2:DFID2:DTID2,...>
                               A comma separated list of file and track IDs
                               that controls which track of a file is
                               appended to another track of the preceding
                               file.
      --append-mode <file|track>
                               Selects how mkvmerge calculates timecodes when
                               appending files.
      <file1> + <file2>        Append file2 to file1.
      <file1> +<file2>         Same as "<file1> + <file2>".
      [ <file1> <file2> ]      Same as "<file1> + <file2>".
      = <file>                 Don't look for and concatenate files with the same
                               base name but with a different trailing number.
      =<file>                  Same as "= <file>".
      ( <file1> <file2> )      Treat file1 and file2 as if they were concatenated
                               into a single big file.
     Attachment support (more global options):
      --attachment-description <desc>
                               Description for the following attachment.
      --attachment-mime-type <mime type>
                               Mime type for the following attachment.
      --attachment-name <name> The name should be stored for the
      --attach-file <file>     Creates a file attachment inside the
                               Matroska file.
      --attach-file-once <file>
                               first Matroska file written.
     Options for each input file:
      -a, --audio-tracks <n,m,...>
                               Copy audio tracks n,m etc. Default: copy all
                               audio tracks.
      -A, --no-audio           Don't copy any audio track from this file.
      -d, --video-tracks <n,m,...>
                               Copy video tracks n,m etc. Default: copy all
                               video tracks.
      -D, --no-video           Don't copy any video track from this file.
      -s, --subtitle-tracks <n,m,...>
                               Copy subtitle tracks n,m etc. Default: copy
                               all subtitle tracks.
      -S, --no-subtitles       Don't copy any subtitle track from this file.
      -b, --button-tracks <n,m,...>
                               Copy buttons tracks n,m etc. Default: copy
                               all buttons tracks.
      -B, --no-buttons         Don't copy any buttons track from this file.
      -m, --attachments <n[:all|first],m[:all|first],...>
                               Copy the attachments with the IDs n, m etc. to
                               all or only the first output file. Default: copy
                               all attachments to all output files.
      -M, --no-attachments     Don't copy attachments from a source file.
      -t, --tags <TID:file>    Read tags for the track from an XML file.
      --track-tags <n,m,...>   Copy the tags for tracks n,m etc. Default: copy
                               tags for all tracks.
      -T, --no-track-tags      Don't copy tags for tracks from the source file.
      --no-global-tags         Don't keep global tags from the source file.
      --no-chapters            Don't keep chapters from the source file.
      -y, --sync <TID:d[,o[/p]]>
                               Synchronize, adjust the track's timecodes with
                               the id TID by 'd' ms.
                               'o/p': Adjust the timecodes by multiplying with
                               'o/p' to fix linear drifts. 'p' defaults to
                               1 if omitted. Both 'o' and 'p' can be
                               floating point numbers.
      --default-track <TID[:bool]>
                               Sets the 'default' flag for this track or
                               forces it not to be present if bool is 0.
      --forced-track <TID[:bool]>
                               Sets the 'forced' flag for this track or
      --blockadd <TID:x>       Sets the max number of block additional
                               levels for this track.
      --track-name <TID:name>  Sets the name for a track.
      --cues <TID:none|iframes|all>
                               Create cue (index) entries for this track:
                               None at all, only for I frames, for all.
      --language <TID:lang>    Sets the language for the track (ISO639-2
                               code, see --list-languages).
      --aac-is-sbr <TID[:0|1]> The track with the ID is HE-AAC/AAC+/SBR-AAC
                               or not. The value ':1' can be omitted.
      --reduce-to-core <TID>   Keeps only the core of audio tracks that support
                               HD extensions instead of copying both the core
                               and the extensions.
      --timecodes <TID:file>   Read the timecodes to be used from a file.
      --default-duration <TID:Xs|ms|us|ns|fps>
                               Force the default duration of a track to X.
                               X can be a floating point number or a fraction.
      --fix-bitstream-timing-information <TID[:bool]>
                               Adjust the frame/field rate stored in the video
                               bitstream to match the track's default duration.
      --nalu-size-length <TID:n>
                               Force the NALU size length to n bytes with
                               2 <= n <= 4 with 4 being the default.
     Options that only apply to video tracks:
      -f, --fourcc <FOURCC>    Forces the FourCC to the specified value.
                               Works only for video tracks.
      --aspect-ratio <TID:f|a/b>
                               Sets the display dimensions by calculating
                               width and height for this aspect ratio.
      --aspect-ratio-factor <TID:f|a/b>
                               First calculates the aspect ratio by multi-
                               plying the video's original aspect ratio
                               with this factor and calculates the display
                               dimensions from this factor.
      --display-dimensions <TID:width>x<height>
                               Explicitly set the display dimensions.
      --cropping <TID:left,top,right,bottom>
                               Sets the cropping parameters.
      --stereo-mode <TID:n|keyword>
                               Sets the stereo mode parameter. It can
                               either be a number 0 - 14 or a keyword
                               (see documentation for the full list).
      --colour-matrix <TID:n>  Sets the matrix coefficients of the video used
                               to derive luma and chroma values from red, green
                               and blue color primaries.
      --colour-bits-per-channel <TID:n>
                               Sets the number of coded bits for a colour
                               channel. A value of 0 indicates that the number is
                               unspecified.
      --chroma-subsample <TID:hori,vert>
                               The amount of pixels to remove in the Cr and Cb
                               channels for every pixel not removed horizontally
                               and vertically.
      --cb-subsample <TID:hori,vert>
                               The amount of pixels to remove in the Cb channel
                               for every pixel not removed horizontally and
                               vertically. This is additive with
                               --chroma-subsample.
      --chroma-siting <TID:hori,vert>
                                How chroma is sited horizontally/vertically.
      --colour-range <TID:n>   Clipping of the color ranges.
      --colour-transfer-characteristics <TID:n>
                               The transfer characteristics of the video.
      --colour-primaries <TID:n>
                               The colour primaries of the video.
      --max-content-light <TID:n>
                               Maximum brightness of a single pixel in candelas
                               per square meter (cd/mē).
      --max-frame-light <TID:n>
                               Maximum frame-average light level in candelas per
      --chromaticity-coordinates <TID:red-x,red-y,green-x,green-y,blue-x,blue-y>
                               Red/Green/Blue chromaticity coordinates as defined
                               by CIE 1931.
      --white-colour-coordinates <TID:x,y>
                               White colour chromaticity coordinates as defined
                               by CIE 1931.
      --max-luminance <TID:float>
                               Maximum luminance in candelas per square meter
                               (cd/mē).
      --min-luminance <TID:float>
                               Mininum luminance in candelas per square meter
                               (cd/mē).
     Options that only apply to text subtitle tracks:
      --sub-charset <TID:charset>
                               Determines the charset the text subtitles are
                               read as for the conversion to UTF-8.
     Options that only apply to VobSub subtitle tracks:
      --compression <TID:method>
                               Sets the compression method used for the
                               specified track ('none' or 'zlib').
     Other options:
      -i, --identify <file>    Print information about the source file.
      -F, --identification-format <format>
                               Set the identification results format
                               ('text', 'verbose-text', 'json').
      --probe-range-percentage <percent>
                               Sets maximum size to probe for tracks in percent
                               of the total file size for certain file types
                               (default: 0.3).
      -l, --list-types         Lists supported input file types.
      --list-languages         Lists all ISO639 languages and their
                               ISO639-2 codes.
      --capabilities           Lists optional features mkvmerge was compiled with.
      --priority <priority>    Set the priority mkvmerge runs with.
      --ui-language <code>     Force the translations for 'code' to be used.
      --command-line-charset <charset>
                               Charset for strings on the command line
      --output-charset <cset>  Output messages in this charset
      -r, --redirect-output <file>
                               Redirects all messages into this file.
      --debug <topic>          Turns on debugging output for 'topic'.
      --engage <feature>       Turns on experimental feature 'feature'.
      @optionsfile             Reads additional command line options from
                               the specified file (see man page).
      -h, --help               Show this help.
      -V, --version            Show version information.
      --check-for-updates      Check online for the latest release.
    Please read the man page/the HTML documentation to mkvmerge. It
    explains several details in great length which are not obvious from
    this listing.
    C:\Users\Saiyan>-o HDR_To_SDR_LUT.mkv \
    '-o' is not recognized as an internal or external command,
    operable program or batch file.
    C:\Users\Saiyan>      --colour-matrix 0:9 \
    '--colour-matrix' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --colour-range 0:1 \
    '--colour-range' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --colour-transfer-characteristics 0:16 \
    '--colour-transfer-characteristics' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --colour-primaries 0:9 \
    '--colour-primaries' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --max-content-light 0:1000 \
    '--max-content-light' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --max-frame-light 0:300 \
    '--max-frame-light' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --max-luminance 0:1000 \
    '--max-luminance' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --min-luminance 0:0.01 \
    '--min-luminance' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --chromaticity-coordinates 0:0.68,0.32,0.265,0.690,0.15,0.06 \
    '--chromaticity-coordinates' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --white-colour-coordinates 0:0.3127,0.3290 \
    '--white-colour-coordinates' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --attachment-mime-type application/x-cube \
    '--attachment-mime-type' is not recognized as an internal or external command,
    C:\Users\Saiyan>      --attach-file HDR_To_SDR_LUT.cube \
    '--attach-file' is not recognized as an internal or external command,
    C:\Users\Saiyan>      HDR_To_SDR_LUT.mp4
    'HDR_To_SDR_LUT.mp4' is not recognized as an internal or external command,
    C:\Users\Saiyan>
    I have moved the files to C:/Users/Saiyan and changed their paths before pasting it to CMD. I have checked over and over again and I am the only User and the Admin. Checked every file so they are not only read-able or locked in case this might have been the issue.
    I removed the starting C:\Users\Saiyan\ and only kept the hdr_metadata-master\hdr_metadata-master\windows\64bits\mkvmerge.exe since CMD starts with the line "C:\Users\Saiyan>", did not work as well. I did a lot of other things which would take a whole page to write down, but nothing works.
    I post this here with the hope of maybe one you will be able to help me with this issue. Please, I am desperate right now as I have tried to solve this for over 10 hours or so now. The inside of my head is like a warzone right now. Where did I go wrong and made the mistake??
    Thanks in advance!!
    EDIT: If there is an alternate method to attach/apply LUT's to a video then please let me know
    Apr 2007
    Australia
    [QUOTE=LegendarySaiyan;2649856]
          HDR_To_SDR_LUT.mp4
    Maybe?
    C:\Users\Saiyan\hdr_metadata-master\hdr_metadata-master\windows\64bits\mkvmerge.exe ^
        -o HDR_To_SDR_LUT.mkv ^
        --colour-matrix 0:9 ^
        --colour-range 0:1 ^
        --colour-transfer-characteristics 0:16 ^
        --colour-primaries 0:9 ^
        --max-content-light 0:1000 ^
        --max-frame-light 0:300 ^
        --max-luminance 0:1000 ^
        --min-luminance 0:0.01 ^
        --chromaticity-coordinates 0:0.68,0.32,0.265,0.690,0.15,0.06 ^
        --white-colour-coordinates 0:0.3127,0.3290 ^
        --attachment-mime-type application/x-cube ^
        --attach-file HDR_To_SDR_LUT.cube ^
        HDR_To_SDR_LUT.mp4
    Cheers.
  3. Thank you for your reply
    I still get the "Error: no output file name was given."
    And then I get this
    C:\Users\Saiyan>    -o HDR_To_SDR_LUT.mkv ^
    More?     --colour-matrix 0:9 ^
    More?     --colour-range 0:1 ^
    More?     --colour-transfer-characteristics 0:16 ^
    More?     --colour-primaries 0:9 ^
    More?     --max-content-light 0:1000 ^
    More?     --max-frame-light 0:300 ^
    More?     --max-luminance 0:1000 ^
    More?     --min-luminance 0:0.01 ^
    More?     --chromaticity-coordinates 0:0.68,0.32,0.265,0.690,0.15,0.06 ^
    More?     --white-colour-coordinates 0:0.3127,0.3290 ^
    More?     --attachment-mime-type application/x-cube ^
    More?     --attach-file HDR_To_SDR_LUT.cube ^
    More?     HDR_To_SDR_LUT.mp4
    And when I press enter this comes up:
    EDIT: What I do not understand is it says "no output file name was given." when I already have with "-o HDR_To_SDR_LUT.mkv", and then it says "'-o' is not recognized as an internal or external command,
    operable program or batch file."
    Apr 2007
    Australia
    Check the first line of the batch file for the caret symbol:
    EDIT: Without the caret symbol to signify 'continues on the next line':
    mkvmerge.exe is running as a command with no parameters.
    -o is a second command - which is unknown.
    Cheers.
  5. I included the caret^ symbol on the first line as well. The thing is, it does read the mkvmerge and execute, but I guess it can't continue because the first Error I get is the "Error: no output file name was given."
    Btw moved everything to my User folder now and pasted this, same result
    C:\Users\Saiyan\mkvmerge.exe ^
        --attach-file C:\Users\Saiyan\HDR_To_SDR_LUT.cube ^
        C:\Users\Saiyan\HDR_To_SDR_LUT.mp4
    Is there something wrong with this line "-o HDR_To_SDR_LUT.mkv ^"
    Apr 2007
    Australia
    EDIT: I made a mistake. Please read this post again.
    I don't think so; try putting double quotes around the file name.
        -o "C:\Users\Saiyan\Documents\HDR_To_SDR_LUT.mkv" ^
        "C:\Users\Saiyan\HDR_To_SDR_LUT.mp4"
    Shorten the output file name and save it to a folder you KNOW you have read/write permissions on.
    Apr 2007
    Australia
    I just ran a quick test. Which worked fine.
    Please note the output file parameter.
    "C:\Program Files\MKVToolNix\mkvmerge.exe" ^
    	--ui-language en ^
            --output "testzzz.mkv" ^
    	--language 0:eng ^
    	--language 1:eng "test2.mkv" ^
    	--language 0:eng "test2.ass" ^
    	--track-order 0:0,0:1,1:0
    	pause
  8. Moved all files into Documents folder and did try from there.
    tried:
    -o "HDR.mkv" ^
    -o out "HDR.mkv" ^
    --output "HDR.mkv" ^
    Nothing
    Btw, I appreciate the help you are providing me with. Thank you!
    EDIT: I will try out -o "C:\Users\Saiyan\Documents\HDR_To_SDR_LUT.mkv" ^ now
  9. Alright!!!
    This worked:
    C:\Users\Saiyan\Documents\mkvmerge ^
    -o C:\Users\Saiyan\Documents\HDR.mkv ^
    --attach-file C:\Users\Saiyan\Documents\HDR_To_SDR_LUT.cube ^
    C:\Users\Saiyan\Documents\HDR_To_SDR_LUT.mp4
    THANK YOU VERY MUCH!! I appreciate it!! I really do!
    Now, it remains to see if my Custom SDR LUT will work on YouTube's SDR Conversion
    EDIT: Yes, it works! Thanks a lot again, appreciate the help
  10. Hello everyone,
    Can someone please confirm that they've used the SDR conversion feature recently and it worked?
    I tried all kinds of codecs and ways to attach a .cube in the mkv but it would just not work.
    I checked every time to ensure that the LUT was actually attached but with no success in the actual YT conversion.
    Thank you for your help!
    All the best
