Results 1 to 11 of 11
  1. interestingly, we have a problem on one PC that does not want to run x264.exe, it starts and silently exits, but if run in cmd as administrator it gives more readings:
    raw [info]: 3840x2160p 0:0 @ 2997/50 fps (cfr)
    x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
    x264 [info]: profile High, level 5.2
    x264 [error]: malloc of size 26199520 failed
    x264 [error]: x264_encoder_encode failed
    PC info:
    		Operating System
    			Windows 10 Home 64-bit
    		CPU
    			AMD Ryzen 9 3900X	45 °C
    			Matisse 7nm Technology
    		RAM
    			64.0GB Dual-Channel Unknown @ 1599MHz (16-18-18-38)
    		Motherboard
    			ASUSTeK COMPUTER INC. TUF GAMING X570-PLUS (WI-FI) (AM4)	32 °C
    		Graphics
    			LEN C32q-20 (2560x1440@60Hz)
    			2048MB ATI AMD Radeon HD 7700 Series (ATI)	43 °C
    		Storage
    			465GB Seagate FireCuda SCSI Disk Device (SATA (SSD))
    			4657GB TOSHIBA HDWE150 SCSI Disk Device (SATA )
    			447GB SanDisk Ultra II SCSI Disk Device (SATA (SSD))
    		Optical Drives
    			No optical disk drives detected
    		Audio
    			Realtek High Definition Audio
    Has anyone some idea what could be the problem?
    Mar 2008
    Russian Federation
    Which build of x264.exe are you using? Are you trying to encode 4K video with 32-bit x264.exe? If you need 64-bit x264.exe you can download it from: https://artifacts.videolan.org/x264/release-win64/
  3. Thanks.
    Using 64bit build. Tested even with that latest 64bit build from that page, the same problem.
    Dec 2017
    Canada
    May be totally irrelevant, but there's a setting in the BIOS called Above 4G decoding (something to do with memory allocation). Maybe the video card needs to have more on-board VRAM; I have no experience with encoding, so I'm just guessing.
  5. DECEASED
    Jun 2009
    Heaven
    Originally Posted by _Al_ View Post
    ............Has anyone some idea what could be the problem?
    According to this post in Doom9's forum ( https://forum.doom9.org/showthread.php?p=1333784#post1333784 ),
    MAYBE the problem is in the encoding settings that you gave to x264.exe
    Originally Posted by Dark Shikari
    The memory usage due to the insane --bframes value, combined with tesa, combined with b-adapt 2, is much more of an issue.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  6. Thanks, I tried to limit buffers, did not help,
    but I narrowed it down to vapoursynth line:
    from nnedi3_resample import nnedi3_resample
    clip = nnedi3_resample(clip, clip.width * 2, clip.height * 2, mode='znedi3')
    without nnedi3_resample it works. Dll's are used the same, portable solution, compiled to exe, but on that particular computer it just does not work.
    Is there some alternative for a decent quick double upscale HD to 4K roughly for vapoursynth, for real videos, not anime?
    EDIT: Heck, it does not work even with simple upscale:
    clip = core.resize.Lanczos(clip, clip.width * 2, clip.height * 2)
    so it must be something with RAM related or so, it just cannot handle higher resolution ...
  7. The whole python script is here, but not sure if it helps. It seams that encoding to higher resolution crashes, if I remove that upscaling line, it works.
    PHP Code:
    #python code, not php
    import vapoursynth as vs
    from vapoursynth import core
    import sys
    import os
    import loadDLL
    import load
    from pathlib import Path
    import subprocess
    try:
    path sys._MEIPASS
        IS_FROZEN
    =True
    except AttributeError
    IS_FROZEN=False
        TOOL_DIR
    r'F:\path_to_\ENCODER_12\tools'
    VS_PLUGINS_DIR ''
    is_okdlls_log loadDLL.vapoursynth_dlls(corer'F:\path_to_\e2\vapoursynth64\plugins')
    if
    IS_FROZEN:
    TOOL_DIR os.path.join(path,'tools')
    VS_PLUGINS_DIR os.path.join(path,'vapoursynth64\plugins')
    isDLLS_LOADEDDLLS_LOG loadDLL.vapoursynth_dlls(coreVS_PLUGINS_DIR)
    def to_4k(sources):
    my_loader load.Sources()
    x264   Path(TOOL_DIR) / "x264.exe"
    MP4BOX Path(TOOL_DIR) / "MP4Box.exe"
    for source_path in sources:
    data my_loader.get_dataclasses([source_path])
    clip data[0].clip
    if data[0].load_isError:
                print(
    data[0].load_log_error)
                continue
    clip nnedi3_resample(clipclip.width 2clip.height 2mode='znedi3')
    path Path(source_path)
    output path.parent f'{path.stem}_4k.mp4'
    temp_output path.parent f'{path.stem}_4k.264'
    fps clip.fps.numerator/clip.fps.denominator
    print(f'\nencoding:     {path}\nnew 4K file:  {output}')
    cmd = [x264'--frames',           f'{len(clip)}',
    '--input-csp',         'i420',
    '--demuxer',           'raw',
    '--input-depth',       '8',
    '--input-res',        f'{clip.width}x{clip.height}',
    '--fps',              f'{fps}',
    '--crf',               '17',
    '--vbv-maxrate',       '70000',
    '--vbv-bufsize',       '70000',
    '--keyint',            '50',
    '--tune',              'film',
    '--colorprim',         'bt709',
    '--transfer',          'bt709',
    '--colormatrix',       'bt709',
    '--output',             temp_output,
    process subprocess.Popen(cmdstdin=subprocess.PIPE)
    clip.output(process.stdin)
    process.communicate()
    mp4box_cmd = [MP4BOX,
    '-add' f'{temp_output}:fps={fps}',
    ##                         '-add',  f'{source_path}#audio',
    '-new',  output]
    process subprocess.Popen(mp4box_cmd)
            try:
    os.remove(temp_output)
    except:
    pass
    if __name__ == '__main__':
    sources    = []
    error_text ''
    if len(sys.argv) > 1:
            for
    arg in sys.argv[1:]:
    sources.append(arg)
    to_4k(sources#rather just double resolution
  8. DECEASED
    Jun 2009
    Heaven
    deleted
  9. Originally Posted by _Al_ View Post
    Remember, doubling the width and height of the frame requires four times as much memory.
    It literally told you that already:
    malloc = Memory ALLOCation
    The question is why a 26 MB allocation is failing on a computer with 64 GB of RAM. You have only 2 GB of video memory. If you're using the graphics card for any filtering or encoding that might run into a problem -- but I don't see any of that in your posts. As was mentioned before, each 32 bit process is limited to 2 to 3 GB of RAM usage (depending on setup), even on 64 bit Windows. So 32 bit encoders with long GOPs and large frame sizes will run into problems. 64 bit encoders shouldn't run into problems with 2K or 4K video and "normal" settings. Another possibility is a bug in the software -- a "memory leak" where it fails to deallocate memory it's no longer using but keeps allocating more as processing continues. The system doesn't realize the program is no longer using the old memory and keeps giving the program more. Eventually the system runs out of memory.
  10. "problem on one pc" implies that the same script works on another pc - is that right ? the problem is isolated to that one specific pc with 3900x , 64gb ?
    Did you try vspipe method with -c y4m to rule out some raw issue ?
  11. Thanks,guys, yes it works on couple of PC's just one gives this error.
    Tested x264.exe --demuxer y4m ...., but on that PC it failed (4k resolution, not HD). For now I was not able to test: vspipe command line loading script and piping it to x264 using command prompt.
    But was able to test it quick like binaries compiled from Python and it failed again: vspipe loading vpy script, piped to x264 , it failed again. All scripts work, just that one PC gives problem.
    That last main script, to simplified it a bit, was this:
    import os
    from subprocess import Popen, PIPE
    source_path = r'F:/video.mp4'
    #getting clip just for some video properties, otherwise clip gets processed in 'double_resolution.py'
    clip = core.lsmas.LibavSMASHSource(source_path)
    fps  = clip.fps.numerator/clip.fps.denominator
    PATH        = Path(os.getcwd()) #Path(sys._MEIPASS) #if frozen
    vpy_script  = PATH / 'double_resolution.py'
    MODULES_DIR = PATH / 'python_modules'
    TOOL_DIR    = PATH / 'tools'
    VSPipe      = PATH / 'VSPipe.exe'
    x264        = TOOL_DIR / 'x264.exe'
    Mp4box      = TOOL_DIR / 'MP4Box.exe'
    ##import loadDLL #if frozen
    ##VS_PLUGINS_DIR = PATH / 'vapoursynth64/plugins'
    ##isDLLS_LOADED, DLLS_LOG = loadDLL.vapoursynth_dlls(core, VS_PLUGINS_DIR)
    path        = Path(source_path)
    output      = path.parent / f'{path.stem}_4k.mp4'
    temp_output = path.parent / f'{path.stem}_4k.264'
    vspipe_cmd = [VSPipe,   '--container',  'y4m',
                            '--arg',       f'source_path={source_path}',
                            '--arg',       f'modules_dir={str(MODULES_DIR)}',
                            vpy_script,
    x264_cmd = [x264,       '--frames',           f'{len(clip)}',
                            '--demuxer',           'y4m',
                            '--crf',               '17',
                            '--keyint',            '50',
                            '--tune',              'film',
    mp4box_cmd = [Mp4box,   '-add' , f'{temp_output}:fps={fps}',
                            '-new',  output]
    p1 = Popen(vspipe_cmd, stdout=PIPE, stderr=PIPE)
    p2 = Popen(x264_cmd, stdin=p1.stdout, stdout=PIPE, stderr=PIPE)
    p1.stdout.close()
    p2.communicate()
    p = Popen(mp4box_cmd)
    p.communicate()
    and its attribute "double_resolution.py" vapoursynth script,where vspipe passes variables (sets globals) source_path and modules_dir:
    import sys
    sys.path.append(modules_dir)
    import mvsfunc
    clip.set_output()
    That works, sometimes as python vspipe crashes for some reason, but if repeating it is ok. Binaries with no problem with similar setup adjusted for portable vs and python. Except that one PC.
    Divers were updated , not remotely sure what the problem could be. That PC does not have python or vapoursynth installed, so everything is a portable setup or binaries, but I don't think it matters, it is just that higher resolution problem.
