Big thumbs up for Sefy's Classical Newbies Guide! Works like a charm. :)
My first ripped movie works great!
Now for the question: My second attempt, ripping "What Women Want," worked fine in my standalone player for 45 minutes or so.
Then the audio went "zziiiip" in a really high-pitched squeal and the whole movie froze.
I can skip to the next chapter and it will play fine from that point on.
I have it re-encoding in TMPGEnc today while I'm at the office, maybe that will fix it?
Any experience with this problem?
Thanks, all.
Definitely one of a few things, get it all the time:
1 - The media you are using is crap and therefore you didn't get a good burn.
2 - The device you are using is having a hard time with the media.
3 - Check the media for smudges or scratches.
4 - Overuse or heat.
To Fix:
1 - Keep trying different brands. For me, I've settled on Digital Media CD-R and CD-RW from Circuit City. Some players handle the color or opaqueness of the dye used better than others.
2 - Try using CD-RW instead of CD-R. Some players don't say they explicitly support or don't support CDR/CDRW, usually CDRW will work OK. My previous Panasonic RV30 was one of these, same with my 4yr laptop. They only liked CDRW.
3 - A simple fingerprint smudge or scratch may do this to you. Get a good cleaner or one of the 'disc doctors' that can clean up a disc for you.
4 - To solve the overuse/heat problem, invest in a good CD/DVD rewinder. It will save your player and make your media last longer. I have used one you can have for US$30....let me know if you're interested and we can hook up.
Good luck...Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Thanks, neomaine.
Let's see... I'm using a CD-R/W compatible Panasonic player.
It's burned on a "silvery" Office Depot CD-R. Are the bluish media preferred for standalone players?
Brand new disc- no smudges or scratches.
CD/DVD rewinder??? :P
The odd thing is that the SAME player just played another ripped movie on the SAME media, so I don't think that's it.
Can a bad encode produce the same results? -
Glad to hear you like the guide
As for your question, i always suggest to play the movie before encoding, sure it may take time, but it might save you a media
Also, i agree that sometimes a media can go bad for no reason, i've nearly lost my Part 6 of Star Blazers because the media suddenly got an air bubble for no good reason, luckily i still had the Part 6 Bin/Cue on my HDD so i can burn it to another media.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
A moment of praise for AnyDVD HD & BD Rebuilder!
By funnel71 in forum Blu-ray RippingReplies: 3Last Post: 30th Jul 2009, 07:10 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
