  1. Whenever I try to load a clip into Premiere Pro, the video part of it doesn’t load; only the audio does.
    I tried to fix this by going to C:/Program Files/Adobe/Common/Plugins/7.0/Mediacore and then deleting all the files within the folder, and it worked at first but then the problem happened again.
    Mar 2008
    There are probably some specifics about the clip properties that are coming into play.
    Open the video in mediainfo, put it in text view, and post the info here
  3. I'm a Super Moderator johns0's Avatar
    canada
    Don't upload a text file of the results,just a text pasted upload.
  4. This is one of them, but this happens with pretty much every video file
    Format : AVI
    Format settings : rec
    File size : 270 MiB
    Duration : 23 min 53 s
    Overall bit rate : 1 582 kb/s
    Video
    Format : VC-1
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Bit rate : 1 430 kb/s
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 (24000/1001) FPS
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.194
    Stream size : 244 MiB (90%)
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : FF-2
    Duration : 23 min 52 s
    Bit rate : 137 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Stream size : 23.5 MiB (9%)
    Alignment : Split across interleaves
    Interleave, duration : 21 ms (0.51 video frame)
    Interleave, preload duratio : 702 ms
    Title : fma01 LPCM T01 48KHz
    Mar 2008
    Possibly the program doesn't like Windows Media (wmv9) in AVI files
    I don't have any such files nor do I have Premiere but you could
    Probably convert to an intermediate lossless and use that with A.P.
    For example, open the source in Vdub2,
    https://www.videohelp.com/software/VirtualDub2
    select video/compression/FFmpeg FFV1 compression
    Hit Configure and set it like this. Ok out, File/Save Video,
    save as type avi
    Perhaps somebody else will confirm and/or have other advice
