    Sep 2021
    Valencia
    Hello:
    There are some live sports videos from some web site, I want to download the video in local disk and play back later on. I can see the video from Google Chrome browser, but using streamlink (version 3.1.1), the following command failed.
    D:\Videos\Download>streamlink --http-header "Referer=https://live-streamfootball.com/" --hls-duration 00:00:3000 https://live.wowaha.tv/live/10/chunks.m3u8 best -o Test.mp4 -l debug
    [cli][debug] OS: Windows 10
    [cli][debug] Python: 3.9.8
    [cli][debug] Streamlink: 3.0.3
    [cli][debug] Requests(2.26.0), Socks(1.7.1), Websocket(1.2.1)
    [cli][debug] Arguments:
    [cli][debug] url=https://live.wowaha.tv/live/10/chunks.m3u8
    [cli][debug] stream=['best']
    [cli][debug] --loglevel=debug
    [cli][debug] --output=Test.mp4
    [cli][debug] --hls-duration=3000
    [cli][debug] --hls-segment-threads=10
    [cli][debug] --ffmpeg-ffmpeg=C:\Program Files\StreamLink\ffmpeg\ffmpeg.exe
    [cli][debug] --http-header=[('Referer', 'https://live-streamfootball.com/')]
    [cli][info] Found matching plugin hls for URL https://live.wowaha.tv/live/10/chunks.m3u8
    [plugins.hls][debug] URL=https://live.wowaha.tv/live/10/chunks.m3u8; params={}
    [utils.l10n][debug] Language code: en_US
    [cli][info] Available streams: live (worst, best)
    [cli][info] Opening stream: live (hls)
    [stream.hls][debug] Reloading playlist
    [cli][debug] Pre-buffering 8192 bytes
    [stream.hls][debug] Segments in this playlist are encrypted
    [stream.hls][debug] First Sequence: 789; Last Sequence: 794
    [stream.hls][debug] Start offset: 0; Duration: 3000; Start Sequence: 792; End Sequence: None
    [stream.hls][debug] Adding segment 792 to queue
    [stream.hls][debug] Adding segment 793 to queue
    [stream.hls][debug] Adding segment 794 to queue
    Exception in thread Thread-HLSStreamWriter:
    File "threading.py", line 973, in _bootstrap_inner
    File "C:\Program Files (x86)\Streamlink\pkgs\streamlink\stream\segmented. py", line 200, in run
    self.write(segment, result, *data)
    File "C:\Program Files (x86)\Streamlink\pkgs\streamlink\stream\hls.py", line 162, in write
    return self._write(sequence, *args, **kwargs)
    File "C:\Program Files (x86)\Streamlink\pkgs\streamlink\stream\hls.py", line 177, in _write
    decryptor = self.create_decryptor(sequence.segment.key, sequence.num)
    File "C:\Program Files (x86)\Streamlink\pkgs\streamlink\stream\hls.py", line 88, in create_decryptor
    return AES.new(self.key_data, AES.MODE_CBC, iv)
    File "C:\Program Files (x86)\Streamlink\pkgs\Crypto\Cipher\AES.py", line 232, in new
    return _create_cipher(sys.modules[__name__], key, mode, *args, **kwargs)
    File "C:\Program Files (x86)\Streamlink\pkgs\Crypto\Cipher\__init__.py", line 79, in _create_cipher
    return modes[mode](factory, **kwargs)
    File "C:\Program Files (x86)\Streamlink\pkgs\Crypto\Cipher\_mode_cbc.py", line 274, in _create_cbc_cipher
    cipher_state = factory._create_base_cipher(kwargs)
    File "C:\Program Files (x86)\Streamlink\pkgs\Crypto\Cipher\AES.py", line 93, in _create_base_cipher
    raise ValueError("Incorrect AES key length (%d bytes)" % len(key))
    ValueError: Incorrect AES key length (64 bytes)
    [stream.hls][debug] Adding segment 795 to queue
    [stream.hls][debug] Adding segment 796 to queue
    [stream.hls][debug] Adding segment 797 to queue
    [stream.hls][debug] Adding segment 798 to queue
    [stream.hls][debug] Adding segment 799 to queue
    [stream.hls][debug] Adding segment 800 to queue
    [stream.hls][debug] Adding segment 801 to queue
    [stream.hls][debug] Adding segment 802 to queue
    [stream.hls][debug] Adding segment 803 to queue
    [stream.hls][debug] Adding segment 804 to queue
    [stream.hls][debug] Adding segment 805 to queue
    [stream.hls][debug] Adding segment 806 to queue
    [stream.hls][debug] Adding segment 807 to queue
    [stream.hls][debug] Adding segment 808 to queue
    [stream.hls][debug] Adding segment 809 to queue
    [stream.segmented][debug] Closing worker thread
    [stream.segmented][debug] Closing writer thread
    [cli][error] Try 1/1: Could not open stream <HLSStream('https://live.wowaha.tv/live/10/chunks.m3u8', None)> (Failed to read data from stream: Read timeout)
    error: Could not open stream <HLSStream('https://live.wowaha.tv/live/10/chunks.m3u8', None)>, tried 1 times, exiting
    [cli][info] Closing currently open stream...
    D:\Videos\Download>"C:\Program Files\streamlink\bin\streamlink.exe" --http-header "Referer=https://live-streamfootball.com/" --hls-duration 00:00:3000 https://live.wowaha.tv/live/25/chunks.m3u8 best -o Test.mp4 -l debug
    [cli][debug] Streamlink: 3.1.1
    [cli][debug] url=https://live.wowaha.tv/live/25/chunks.m3u8
    [cli][info] Found matching plugin hls for URL https://live.wowaha.tv/live/25/chunks.m3u8
    [plugins.hls][debug] URL=https://live.wowaha.tv/live/25/chunks.m3u8; params={}
    [cli][debug] Checking file output
    [stream.hls][debug] First Sequence: 1408; Last Sequence: 1413
    [stream.hls][debug] Start offset: 0; Duration: 3000; Start Sequence: 1411; End Sequence: None
    [stream.hls][debug] Adding segment 1411 to queue
    [stream.hls][debug] Adding segment 1412 to queue
    [stream.hls][debug] Adding segment 1413 to queue
    File "C:\Program Files\streamlink\pkgs\streamlink\stream\segmented. py", line 200, in run
    File "C:\Program Files\streamlink\pkgs\streamlink\stream\hls.py", line 197, in write
    File "C:\Program Files\streamlink\pkgs\streamlink\stream\hls.py", line 222, in _write
    File "C:\Program Files\streamlink\pkgs\streamlink\stream\hls.py", line 121, in create_decryptor
    File "C:\Program Files\streamlink\pkgs\Crypto\Cipher\AES.py", line 232, in new
    File "C:\Program Files\streamlink\pkgs\Crypto\Cipher\__init__.py", line 79, in _create_cipher
    File "C:\Program Files\streamlink\pkgs\Crypto\Cipher\_mode_cbc.py", line 274, in _create_cbc_cipher
    File "C:\Program Files\streamlink\pkgs\Crypto\Cipher\AES.py", line 93, in _create_base_cipher
    [stream.hls][debug] Adding segment 1414 to queue
    [stream.hls][debug] Adding segment 1415 to queue
    [stream.hls][debug] Adding segment 1416 to queue
    [stream.hls][debug] Adding segment 1417 to queue
    [stream.hls][debug] Adding segment 1418 to queue
    [stream.hls][debug] Adding segment 1419 to queue
    [stream.hls][debug] Adding segment 1420 to queue
    [stream.hls][debug] Adding segment 1421 to queue
    [stream.hls][debug] Adding segment 1422 to queue
    [stream.hls][debug] Adding segment 1423 to queue
    [stream.hls][debug] Adding segment 1424 to queue
    [stream.hls][debug] Adding segment 1425 to queue
    [stream.hls][debug] Adding segment 1426 to queue
    [stream.hls][debug] Adding segment 1427 to queue
    [cli][error] Try 1/1: Could not open stream <HLSStream('https://live.wowaha.tv/live/25/chunks.m3u8', None)> (Failed to read data from stream: Read timeout)
    error: Could not open stream <HLSStream('https://live.wowaha.tv/live/25/chunks.m3u8', None)>, tried 1 times, exiting
    D:\Videos\Download>
    The request headers are shown below:
    My question is: how I can add some parameter to streamlink to make the download working.
    The M3U8 link can be some thing like:
    https://live.wowaha.tv/live/2/chunks.m3u8
    https://live.wowaha.tv/live/20/chunks.m3u8
    The web site have other M3U8 links, if not like the above, then usually streamlink works, but for the above links, they always fail.
    Please advise,
    Thanks,
  2. This post is identical to this one you made: https://forum.videohelp.com/threads/404592-How-to-download-some-HLS-and-save-to-local-...ing-streamlink
    And the solution is STILL the same - we need the mother url of the page you are trying to download from so we can ascertain any errors you are making as to whether you have the correct m3u8 or mpd and / or any other required information to make the DL happen via any tools.
    But; you should have realized you have answered your own question with this:
    [Attachment 63541 - Click to enlarge]
    Streamlink will not download encrypted segments. Read the docs.
    Sep 2021
    Valencia
    Hello:
    You can get a number of similar URL from this web page: https://bingsport.com/
    There are always some live sports games, you can click on any of the live games and view the underlying URL for M3U8 links.
    During weekend, there are really a lot.
    You can check now.
