Hello, I'd like to know the difference between:
1) change the fps of a video without re-encoding it, so changing timestamps, for example using mkvtoolnix (mkvmerge --default-duration)
2) change the fps of a video re-encoding it
What is the best choice in term of preserving quality? There will be problems when playing the file modified losslessly?
if I understand correctly, when I encode a video in order to change fps, I "produce" frames and I assign to each frame a timestamp, maybe frames are lost or duplicated. When I use a tool like mkvtoolnix to change fps, I change all timestamps without touching the frames, so quality is preserved, there aren't lost frames and there shouldn't be problems when playing the video: in fact the procedure should be exactly equivalent. Is it correct?
Re-encoding with lossy codecs always loses quality. Changing timestamps doesn't change the quality (though there may be a perceived "quality" difference depending on the frame rate of the video vs. the frame rate of the TV/monitor -- i.e. jerkiness with a frame rate mismatch).
Depending on the original source timebase, and whether this is a "correction" back to that timebase or not, it would also affect the apparent motion consistency of the action, either for better or worse. Depending on the action, it may not be noticeable.
How audio/video lossy and lossless comprasion works?
By Anonymous543 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2022, 16:43 -
Is there any benefit to converting lossy to lossless.
By jpvoodoo in forum Video ConversionReplies: 3Last Post: 11th Jun 2021, 09:20 -
Lossy and Lossless compression: Is one format better than the other?
By Guernsey in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2021, 04:36 -
Quick sanity check: Lossless to lossless encoding HuffYUV to UTVideo
By nicholasserra in forum Video ConversionReplies: 2Last Post: 20th Aug 2020, 11:41 -
A (Most Likely) Dumb Question About Re-encoding Lossy Formats
By enter8 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2019, 19:11
