I have the JimTab M18 Pro. Projector and I have a lot of DVDs that I used MakeMKV on to put them on My Hard Drive.
The Projector can Play MKV Files but it did not Play all of My MKV Files.
So I Converted them to MPEG 4. X 265 and they Play.
But I have the DVDs from the 70's TV Show Land Of The Lost.
And I used MakeMKV on them to put them on My Hard Drive.
So I Concerted them as well to MPEG 4. X 265 but these do not Play on My Projector.
It Says Un Supported File.
Does anybody know why?
I think we have gone over this before.
When some device says it supports a format, that doesn't necessarily mean it supports all variations of the format.
Mkv is a container that can contain a nearly unlimited variety of video codecs and audio codecs. You want to experiment and find out which subset of codecs are also supported. Most likely, it would include mpeg2, mpeg4-asp aka dvix/xvid, h264, and probably h265. That is for video, but there would be a similar subset for audio.
But that is not the end of it...
Codecs like those, esp. h264 and h265 come in a variety of flavors, so they should be considered more like codec families.
You would have to further experiment and see which "flavor" or Level and Profile it supports.
Once you do that, and then (re-)encode only to those Level & Profile subsets, you will have cracked the code and be making files you know will reliably play properly.
Scott -
The manual for the projector should mention what limitations your MKV files must meet for the projector to be able to play them. Alternatively, you can use MediaInfo or another method to check the details for an MKV that the projector does play, and re-encode every MKV you want to use with the projector to match.
If cameras add ten pounds, why would people want to eat them? -
I used MakeMKV on My DVD of the Movie Day Of The Dead.
And it Plays good on the Projector because it can Play MKV Files.
Then I used MakeMKV on My DVD of the TV Show Land Of The Lost and it did not Play.
They are Both the same MKV Format and the Video CODEC is MPEG 2. and they are Both under 2. GB witch JimTab Tells Me they have to be.
I Thought maybe something was going on? -
Something is going on.
But there is no way to know without further details, like Mediainfo readouts of the good & the bad clips.
Could be NTSC vs PAL, could be D1 vs lower rez, could be mpeg2 vs mpeg1, could be weirdness with a GOP, could be a difference of audio codecs...
Scott -
Ok I used MPEG 4. x 265 and Selected a Low Bit Rate to give Me the most Compression and the Video Plays.
So My Projector just needs Small Files.
So I am going to Convert My MKV Files to MPEG 2. because it is good Video Quality.
So I know if You use a Low Bit Rate You get Bad Video Quality but a Small File.
If You use a High Bit Rate You get good Video Quality but a Big File.
So this is the Bit Rates I have to Pick from.
256
512
768
1000
1500
1800
what will give Me a Good Video Quality but somewhat good Compression?
I know if it is a Movie with a lot of FX You need a High Bit Rate
Thanks for the help. -
Stop cutting a square peg to fit a round hole. Spend $50 on an Android Box that will play your files directly.
Using Virtualdub What is the Best Codec to Capture and Best Codec to Save?
By mjgreer in forum Newbie / General discussionsReplies: 32Last Post: 11th Dec 2024, 03:32 -
How to find the right codec
By Grex234 in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2022, 10:52 -
Codec hymt
By Quivak22 in forum Software PlayingReplies: 8Last Post: 14th Oct 2018, 08:40 -
The best codec currently available?
By sophisticles in forum Video ConversionReplies: 9Last Post: 1st Nov 2017, 08:17 -
Recommend 4K codec?
By jfharper in forum Video ConversionReplies: 7Last Post: 26th May 2017, 13:56
