I can use AmarecTV & capture perfectly fine with Extremecap U3 (losless video & 2-channel PCM), as the device is Directshow
But VD2 shows nothing at all (just black box)
Capture does not work either
Any ideas?
sebus
As I discovered Virtualdub2 is not good for capturing, yes it can do it but my results were pretty bad. You could try an older version of virtualdub such as 1.9
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
1.9.11 is recommended by Lordsmurf (down the page a bit):
http://www.digitalfaq.com/forum/video-conversion/1727-virtualdub-filters-pre.html
CANON HF G40 - AVER MEDIA EXTREMECAP U3, AVerMedia ExtremeCap UVC, ...
By Peter76 in forum Capturing and VCRReplies: 2Last Post: 30th Dec 2020, 15:48 -
VirtualDub2 unable to capture from AverMedia C039
By Katherine1 in forum Capturing and VCRReplies: 10Last Post: 1st Jul 2020, 20:04 -
AVerMedia ExtremeCap U3 Colour Ghosting
By GreatGlobox in forum Capturing and VCRReplies: 5Last Post: 25th Sep 2019, 19:50 -
Avermedia Extremecap U3
By jmstack in forum Capturing and VCRReplies: 3Last Post: 8th Aug 2017, 14:51 -
Avermedia ExtremeCap U3 showing random horizontal line
By blümchen in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2017, 09:02
