    Mar 2014
    PALaland
    What would be SAR for a 544x576 4:3 PAL source?
  2. For 4:3 Exactly, it would be 24/17
    4/3 = 544/576 * 24/17
    Mar 2014
    PALaland
    Thanks posion. How do you do that? I got somehow to 1.411 which is the same but had no idea how to make 1.411 look like 24/17. Searched for an online converter for such but couldn't find any.
    Now I would need another SAR, for a 480x576 4:3?
  4. Universal relationship:
    DAR = FAR * SAR
    DAR = Display aspect ratio, the final shape of the picture
    FAR = Frame Aspect Ratio, frame_width:frame_height
    SAR = Sampling Aspect Ratio, relative distance between pixels horizontal:vertical
    algebraic rearrangement gets:
    DAR / FAR = SAR
    Numeric substitution gives:
    4/3 / (480/576) = SAR
    4/3 * 576/480 = SAR
    2304 / 1440 = SAR
    (divide both by 32 gives)
    72 / 45
    (divide both by 9 gives)
    8 / 5 = SAR
    8:5 = SAR
    Or starting at 2304 / 1440 = SAR, calculate all the prime factors calculator yourself, or use a calculator:
    https://www.calculatorsoup.com/calculators/math/prime-factors.php
    2304 / 1440 = SAR
    (2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 3 x 3) / (2 x 2 x 2 x 2 x 2 x 3 x 3 x 5) = SAR
    (remove common values)
    (                    2 x 2 x 2        ) / (                            5) = SAR
                         8                  /                              5  = SAR
    8:5 = SAR
  5. Originally Posted by kodec View Post
    we have 480x576 4:3 resolution, so first we do 576x1.3333333(4:3)= 768, this means our real resolution is 768x576, then final operation is to compare (divide) two resolutions 768x576 and 480x576 ---> 768/480 = 1.6 (16/10) --> SAR is 16/10 or 8/5 (both will work)
