Hi All,
I capture the home video from Sony Hi8 (NTSC) in VirtualDub @ 352x480 (no filters) in raw AVI. I want to know what will be difference, in size, if I were to use Huffy codec. Presently raw AVI is around ~28 GB for 50 min capture.
I just did Indiana Jones TLC last night (@ 352x480 w/ Huffy) and it was 40 GB for 2 hrs. 6 min....
The compression ratio depends on the source video. I typically get compression ratios ranging from 1.2:1 to 1.8:1
Craig
Huffy codec and field threshold
By TaranScorp in forum Capturing and VCRReplies: 7Last Post: 5th May 2011, 13:56 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 21:01 -
huffy -> xvid
By geonuine in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 3rd Nov 2008, 07:49 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 17:52 -
Problem exporting a file with HUFFY UV
By V.A.M in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 18:53
