  1. Dears,
    could you please enlight me what tool can easily rip Bluray audio without ripping entire movie and audio. In HandBrake i have seen that i can do this only while ripping/encoding video and audio together (some audios can do Passthru).
    My task is to get only the audio in source quality
    Thank you very much
    Kind Regards,
    M
    Disc Title: Blah blah blah
    Disc Size: 44 433 595 305 bytes
    Protection: AACS
    BD-Java: Yes
    Extras: Blu-ray 3D
    BDInfo: 0.5.8
    PLAYLIST REPORT:
    Length: 1:41:59.738 (h:m.ms)
    Size: 43 382 968 320 bytes
    Total Bitrate: 56,71 Mbps
    VIDEO:
    Codec Bitrate Description
    MPEG-4 AVC Video 25493 kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1
    MPEG-4 MVC Video 15992 kbps
    AUDIO:
    Codec Language Bitrate Description
    DTS-HD Master Audio English 5300 kbps 7.1 / 48 kHz / 5300 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
    DTS Audio Portuguese 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    DTS Audio Czech 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    DTS Audio Hungarian 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    DTS Audio Spanish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    DTS Audio Polish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    DTS Audio Russian 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    DTS Audio Thai 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    DTS Audio Turkish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
    SUBTITLES:
    Presentation Graphics English 23,849 kbps
    Presentation Graphics Portuguese 17,929 kbps
    Presentation Graphics Czech 16,540 kbps
    Presentation Graphics Hungarian 17,616 kbps
    Presentation Graphics Spanish 17,666 kbps
    Presentation Graphics Polish 17,417 kbps
    Presentation Graphics Russian 17,984 kbps
    Presentation Graphics Thai 14,928 kbps
    Presentation Graphics Turkish 17,077 kbps
    Presentation Graphics Bulgarian 16,135 kbps
    Presentation Graphics Chinese 12,574 kbps
    Presentation Graphics Chinese 14,611 kbps
    Presentation Graphics Croatian 17,671 kbps
    Presentation Graphics Estonian 16,482 kbps
    Presentation Graphics Greek 19,438 kbps
    Presentation Graphics Hebrew 11,888 kbps
    Presentation Graphics Korean 13,196 kbps
    Presentation Graphics Latvian 16,278 kbps
    Presentation Graphics Lithuanian 18,004 kbps
    Presentation Graphics Romanian 16,247 kbps
    Presentation Graphics Slovenian 15,354 kbps
    Presentation Graphics Ukrainian 17,417 kbps
    Presentation Graphics Portuguese 0,093 kbps
    Presentation Graphics Czech 0,097 kbps
    Presentation Graphics Hungarian 0,040 kbps
    Presentation Graphics Spanish 0,042 kbps
    Presentation Graphics Russian 0,015 kbps
    Presentation Graphics Thai 0,021 kbps
    Presentation Graphics Turkish 0,037 kbps
  2. Any advice regarding the tool?
  3. Well you could use MakeMKV wich also remove the copy protection and doesn't re-encode (it is possible for audio tracks but default is pass-through) and then use MKVCleaver to extract the audio from the mkv file created.
    Feb 2006
    dvdfab has a blu-ray audio extractor - https://www.dvdfab.cn/tips/blu-ray-audio-extractor.htm
  5. Name:  pDiPp3F.png
    i felt that
    Anyway, I guess you could use MakeMKV to extract the video, then use ffmpeg (or clever ffmpeg gui) to extract audio. I did that with some beatles videos.
  6. Thank you all.
    I tried both apps. DVDfab and MakeMKV. MakeMKV is much more easier as it does very quickly REMUX from the full Bluray disk. Then i can extract the audio with MKVtoolNix.
    As for the DVDfab, its foggy, as there there different options to extract audio out. If you chose wrongly then its not 1:1 audio as original source.
    I suggest the MakeMKV
    Have a good day
