Hello Guys!
I removed the Anti-reflection and UV-layer from both of my FDR-AX700 with alcohol, following that methode: https://youtu.be/mkLn3x0UfaY
When the alcohol dissolved the layer... somethiong purple liquid was created what I removed too.
Since than, The video is more logherter in darker situations than it was before!!! However in brigt sunligt is tend to glare and less contrasty
Since I use additional AR+UV filter, the original UV layer is not needed.
You gain a lighter system for indoor.... and for outdoor there is the additional filter.
However If I let the factory layer to remain, it means fewer lights for indoor or night environment...
Closed Thread
Results 1 to 30 of 63
Why? Maybe you can explain it. I bought 62MM Sony VARIO-T additional AR UV filter for the camera. IT must be good for that lens system if I need outdoor recording.
Additional UV filter always needed to physically protect the camera lens in outdoor. So factory UV layer + additional UV filter would be crazy, and makes the camera worse.
However in indoor environment it seems lighter than before..... (I feel the effect like the CMOS would be a little bigger, thus brighter)
The older one is 4years old the younger is almost 3 years old, so I don't care about the warranty.
No, I agree that modifying a highly technical and specialized piece of equipment without knowing the engineers' determination of why something is essential or not (and indeed they thought it was essential, otherwise they would not have spent the extra money to coat it), is foolhardy and shortsighted.
But Scott! https://www.ebay.com/itm/373921848717?hash=item570f7a9d8d:g:P-4AAOSwxN5iAokN
I have Karl Zeiss Vario-T anti reflection and UVfilters! Just imagine! That company myde the James Webb space telescope, the most brutal technology in artificial imaging of our time. With its help, mabye we can see not only the DEEP Space, but the deep past.... time travelling to the era of the cradle of the Universe!
We will see how the universe was created in the summer, or early autumn! What level of technology is that.....Last edited by Truthler; 17th Feb 2022 at 16:19.
I'm afraid you got it wrong yet again.
Not Zeiss - Ball & Northrop Grumman.
https://www.prnewswire.com/news-releases/ball-aerospace-built-optics-and-mirror-system...301450794.html
You got it wrong. German Technology did it:
https://www.mpg.de/515241/pressRelease20051206
I know you do not want my opinion but you get it all the same.
The way you word your topic suggests to me that having done what you did you are having second thoughts and seeking some justification for your action.
No self-respecting photographer still or cine would not place a filter over their lens even just for protection purposes - I am a mere amateur in that regard but a filter was the first item for my original SLR and then DSLR. As Scott points out, there must be good reason for the coating.
At least you found out that the lens was made of glass
Notice your link is from 2005 with an expectation in the future. My link is from this last Christmas. Seems NASA changed their minds in the interim and didn't go with Zeiss on this one.
Or, possibly, there are multiple "instruments" on board, and Zeiss/Planck worked on the MIRI and NIRSpec ones, while Ball & Northrop Grumman built the overall.
Tsk, Tsk, Tsk.
https://www.mpg.de/18094339/james-webb-interview-krause-englisch
It is mostly a German machine.
Do you know that nobody can manufacture a CPU or GPU chip without German or Japan printer machines ? When you will hear that AMD or Nvidia or Intel announce a smaller nanometer chip technology, it means, that German firms produced a new industrial printer machines which can do that.
Gotta love it when you hijack your own topic yet again !!!!
Anyway. A few days ago I started a topic about media when I could not understand how items were appearing on my youtube home page without any obvious (no search) input on my part. And this very morning it happens again. But I think I now have it figured out - data harvesting by Google via the Chrome browser and my reading of these forums - could still be wrong but that, for me, is the only logical reason. So here's the topical link:
https://www.youtube.com/watch?v=WESKRnkGXGY
The essence of this video is that the presenter is ranting about why some people over-value lens coatings. He does mention Zeiss amongst other lens manufacturers and ends the video stating that coatings are important but not over so.
People who want to clean their lenses, have to use alcohol, or the more percefctionists use high percentage apple vinegar. (Do not confuse with the low density and cheap apple vinegar what you use for cooking)
Both materials slowly but surely destroy AR-UV coating material (because they dissolve them) after some cleaning process.Last edited by Truthler; 18th Feb 2022 at 05:05.
Well in my limited experience it it is still a BAD idea to remove in the 'excuse' that removal is a consequence of cleaning.
With a filter in place, there is little to no argument to 'clean' the lens - you clean the friggin' filter with a dry cloth. And a filter should, in my limited understandibility, remain attached even in situations where it may not be required.
To advocate the removal of coatings on a 'whim' is reckless and gives this forum no better credibility that the yt-jerks who advocate such measures.
I will not respond, this time, to any perceived abuse but I reserve my rights accordingly.
Most factory coatings on lenses are for Anti-Reflection. And they affect the brightness levels by about 0.01 EV (so, nothing to speak of). Now that you've removed that, good luck with your reflections.
Not a smart thing to do, and not something to ever recommend to others.
Correction: Not anti-reflection only, but like the additional filters, they are also UV filters too. So they have combined task. I think the cameras became visibly lighter.
I have ZEiss T AR-UV filters.
ZEiss invented the anti-reflection coating in 1935. Learn: https://youtu.be/mtmQgoOZ3cw
All of the ZEiss T lenses have own AR-UV filter. Each of the lenses in the lens system individually have that coating too.
Cornucopia, Is your CPU and GPU works well? Maybe because they were printed on German printers , let it be AMD Intel Nvidia etc....Last edited by Truthler; 18th Feb 2022 at 11:19.
Guys I screwed up so everybody must screw up.
Then don't.
Here is the sciense behind the anti-reflection lens coating if you care.
NO, @Truthler, I haven't. Don't, and won't.
Professional photos have always recommended using non-scratch microfiber cloth, kodak lens paper, a blower brush, etc. to clean lenses. And there is specific lens cleaning fluid. It may cost a few cents, but there IS a reason it is recommended. Look it up.
Stop doing harm to your lenses, trying to 1. save a few cents, 2. eek out some unknown self-perceived quantity of extra capability.
I'm still capable shot videos indoor without problems. I'm still shot more detailed videos than any other cameras under 3000$. Please let's don't forget, that these cameras could reach the max visible 4K resolution in ISO IMAGE test charts. Prosumer competitors from Canon Panasonic and JVC are not able to reach the maximal lw/ph values on the resolution test charts.
If I want to shot outside, I use the additional Zeiss T AR-UV filters (anti reflection layer is a Zeiss invention).
I think all true professionals (who work in mega-giga-hyper super productions) remove the AR-UV protecting layers from the front glass of the camera, and they use additional AR-UV filter if it is imortant for the scene.
Without the removal of that filter, you can not shot such movies, where the sunlight and sunbeam effects are important.
Watch this short clip, especially 1:47 and 1:54
https://www.youtube.com/watch?v=M5qTuQLng1gLast edited by Truthler; 19th Feb 2022 at 10:27.
Wrong again, @Truthler.
Sunflare or any general flare (the correct term that you were fishing for) is possible with ANY lens, if the strong light is aimed directly at the camera lens, though a slightly oblique angle with partial obscuring of the source is usually considered the most pleasant effect. At those angles, even multiple AR-coatings cannot fully diminish the effect, and the large dynamic range is still beyond the capability of nearly all sensors to handle, so there is "sensory overload" going on, as well as inter-element lens internal reflection.
You are digging your own hole deeper trying to deflect again.
Even our friend's take on history is suspect. The guy then working at Zeiss in the 1930's did not invent the process. He invented a facet of it. The theory had been around 50 years prior with documentation at least 25 years prior.
But explain this one. If your filter is recc. for Zeiss lenses which, I guess, have this coating, why bother in getting the filter in the first place ?
You will NEVER admit you screwed up. But you do little service to the community to advocate that all should follow your example and jump off the cliff since there will always be a soft landing.
Cornucopia said, that I destroyed my lens, and he started the ordering of the funeral process of my camcorders.
To tell the truth , I did not notice any difference
See my newest recording about some Dodge Srt cars.
>>>>>>>>>>>>> https://sendgb.com/VAhofUcNHuF <<<<<<<<<<<<<Last edited by Truthler; 19th Feb 2022 at 13:21.
Wrong. AR coating in BRitain or US before Germans? Are you serious? Chemistry industry of US and UK were not really innovative, they just adopted (in the most cases) what Germans and French invented. About Glass industry,the US and UK were happy enough if they could make good beer and whiskey bottles before WW2
)))) But lens systems? They were very far to produce lenses in satisfying quality
Help with removing top/front layer of audio (narration)
By jonxtxnr in forum AudioReplies: 0Last Post: 13th Jul 2021, 09:45 -
high core count cpu for x265 encoding good idea?
By sonyzz in forum ComputerReplies: 18Last Post: 6th Mar 2021, 17:57 -
Removing DRM protection after download
By Spiny Norman in forum Video Streaming DownloadingReplies: 13Last Post: 12th Jan 2021, 10:18 -
No Layer Break Selection When Backing Up Dual Layer DVD
By meeshu in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2020, 19:01 -
So what Dual Layer Blu Ray media is good now?
By curiousjosh in forum MediaReplies: 1Last Post: 23rd Apr 2017, 06:21
