In another post of me I got some tips about de-interlacing.
For instance : Handbrake -> Yadif with preset Bob
Now I do some tests with Handbrake with the Preview options.
The loaded file is AVI, Interlaced.
When I set all filters at Off, I expect to get a preview file also Interlaced.
But MediaInfo displays Progressive.
Is this a bug in Handbrake or misunderstanding by me?
The file is captured from a mini DV tape and the parts taken inside the house are noisy.
Yes, my input file is interlaced, so I was surprised to see that with the De-interlace options OFF Handbrake still procudes a de-interlaced (Progressive) file.
But I understand from jagabo, that this is a bug in Handbrake.
Now I am capturing mini DV tapes of my son.
The first one, Interlaced, has according to MediaInfo : Bits/(Pixel*Frame) : 2.357
I think, the best way is cutting it in scenes remaining the output also Interlaced.
But the programs I have tested produce Progressive files, I can only choose MP4, AVI, etc. -
If you want simple cut editing of DV AVI use VirtualDub. Set Video -> Direct Stream Copy. Mark-in, mark-out, File -> Save As AVI... Repeat for each segment you want to save. There will be no change in quality or size.
AviDemux can do this too. Leave Audio and Video set to Copy. Set Output Format to AVI.
Players will not use filters
By HelpPlease in forum Software PlayingReplies: 0Last Post: 14th Jun 2020, 15:43 -
How to use sharpen filters in MeGUI
By Daringbaaz in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2019, 11:38 -
Does LG DR1F9H have filters to be used as a pass-through?
By digicube in forum Capturing and VCRReplies: 3Last Post: 25th Jul 2019, 10:38 -
How do I use QTGMC and Toon filters in handbrake?
By curiosport in forum DVD RippingReplies: 25Last Post: 20th Aug 2018, 07:19 -
Avisynth Filters Help
By max_cady in forum Newbie / General discussionsReplies: 10Last Post: 5th Jun 2017, 12:59
